Using TeeChart with a DLL file
Haianh
Post by Haianh » Wed Feb 03, 2010 6:25 am
I have compiled TeeChart with license in to a dll library file and used it in another application on another PC (non-license) so when I'm running this application the error appeared as follow:
System.Windows.Markup.XamlParseException occurred
  Message="Cannot create instance of 'TChart' defined in assembly 'TeeChart.WPF, Version=3.5.3146.24805, Culture=neutral, PublicKeyToken=98e8c3f289a4e286'. Exception has been thrown by the target of an invocation.  Error at object 'System.Windows.Controls.Grid' in markup file 'ChartControlLib;component/chartcontrol.xaml' Line 7 Position 10."
  Source="PresentationFramework"
  LineNumber=7
  LinePosition=10
I'm using Teechart V3 .NET (TeeChart.WPF.dll - WPF support), Can anyone helps me to solve this problem?
Thanks and best regards,
Binh Duong
Re: Using TeeChart with a DLL file
Post by Yeray » Wed Feb 17, 2010 11:00 am
Hi Binh Duong,
Excuse us for the delayed reply.
I think you should be able to do something similar as what was explained here.
I've also sent to your email the TeeChart for .NET v3 unlocked dll.
