Legend with check boxes--when are they clicked?
TestAlways
Post by TestAlways » Thu Dec 31, 2009 6:56 pm
I have a legend with check boxes turned on--I need to know when one of the check boxes is clicked. How can I know? (I can use the OnCLick event for the chart, but is there anything more narrow?)
Re: Legend with check boxes--when are they clicked?
Post by Yeray » Mon Jan 04, 2010 11:34 am
Hi Ed,
The most accurate I can think right now would be something as following:
uses series, TeCanvas;
var i: Integer;
  Chart1.View3D:=false;
  for i:=0 to 4 do
    Chart1.AddSeries(TPointSeries.Create(self));
    Chart1[i].FillSampleValues();
  Chart1.Legend.CheckBoxes:=true;
procedure TForm1.Chart1ClickLegend(Sender: TCustomChart;
  Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
var i: Integer;
    tmpPnt: TPoint;
    tmpRect: TRect;
  tmpPnt.X:=X;
  tmpPnt.Y:=Y;
  for i:=0 to Chart1.SeriesCount-1 do
    tmpRect.Left:=Chart1.Legend.Left;
    tmpRect.Right:=Chart1.Legend.Left + Chart1.Legend.Width - 1;
    tmpRect.Bottom:=Chart1.Legend.Item[i].Top + Chart1.Legend.Item[i].SymbolRect.Bottom - Chart1.Legend.Item[i].SymbolRect.Top + 3;
    if (i = 0) then tmpRect.Top:=Chart1.Legend.Item[i].Top-3
    else tmpRect.Top:=Chart1.Legend.Item[i].Top-2;
    if PtInRect(tmpRect,tmpPnt) then
      showmessage('series ' + IntToStr(i+1));
      break;
