Problem in Histogram axis maximum value.
ML2
Post by ML2 » Thu Dec 10, 2009 12:01 pm
i am using TeeChart WPF.
Created a histogram chart, it is working very perfectly, no problems till now.
Now i need to set the Bottom axis scale at runtime, so i create a UI and set the chart bottom axis maximum and minimum values.
But when i set the Maximum value more than 850 or so i get an exception "Width must be non-negative."
I am using version 3.5.3225.32185.
Re: Problem in Histogram axis maximum value.
Post by Yeray » Thu Dec 10, 2009 3:18 pm
Hi ML2,
First of all note that the version you mention was released on November 2008 and several maintenance releases have been released since then fixing multiple problems and adding many enhancements. So please, try downloading the latest version available at the client area and see f the problem persists.
Second, please, send us a simple example project we can run as-is to reproduce the problem here. You can post your files directly here in the forums attaching them to a message.
