TeeChart6 Builder C++ 6 - Freezing Application
A Line Series, change the XAxis to DateTime type, change the Date time format to include hour min, causes the application to freeze either at design time and runtime (changing properties via teechart editor or accessing properties directly).
Hi.
Yes, this is a known bug and it's related to the internal code for splitting axis labels in several lines. Workaround is to display axis label in single line (set LabelsMultiLine property to false). This bug has been fixed in TeeChart v7.0.
Marjan Slatinek,
