Fibonacci tool - levels and drag mouse
ronaldohp
Post by ronaldohp » Wed Nov 04, 2009 4:56 pm
Hi guys,
I want to add more levels in the default three levels avaiable on the fibonacci tool, but when i add more levels they desapear when I open
the tool again.
Do someone know how I can add more levels in the fibonacci tool?
Another question is about drag mouse on the chart and draw a rectangle. Is this possible?
Ronaldo HP
Re: Fibonacci tool - levels and drag mouse
Post by Yeray » Thu Nov 05, 2009 10:32 am
Hi Ronaldo,
ronaldohp wrote:I want to add more levels in the default three levels avaiable on the fibonacci tool, but when i add more levels they desapear when I open
the tool again.
  Chart1.View3D:=false;
  Series1.FillSampleValues(25);
  ChartTool1.Series:=Series1;
  ChartTool1.StartX:=Series1.DateValues[5];
  ChartTool1.StartY:=Series1.CloseValues[5];
  ChartTool1.EndX:=Series1.DateValues[15];
  ChartTool1.EndY:=Series1.CloseValues[15];
  ChartTool1.Levels.Add;
  ChartTool1.Levels[ChartTool1.Levels.Count-1].Value:=70.5;
ronaldohp wrote:Another question is about drag mouse on the chart and draw a rectangle. Is this possible?
Yes, you should use OnMouseDown, OnMouseMove, OnMouseUp and OnAfterDraw events to do it. Here in the forums you will find some examples:
http://www.teechart.net/support/viewtop ... f=3&t=9421
ronaldohp
Post by ronaldohp » Fri Nov 06, 2009 7:22 pm
Well, thanks by the usefull answer, but I would to specify my question:
I want to draw a rectangle dragging the mouse over a graphic and in the same time draw the lines of Fibonacci levels.
The started point, for example, will be the most lower price of a candle chart and the ended point will be the most high price of the trend,
and while I move the mouse from lower to high points the lines level of Fibonacci will be drawed.
Thanks for the help
Ronaldo HP
Post by Yeray » Mon Nov 09, 2009 12:39 pm
Hi Rolando,
Please take a look at this example but note that the conditions at OnAfterDraw should be probably refined:
uses series, CandleCh, TeeFibonacci;
var Series1: TCandleSeries;
    ChartTool1: TFibonacciTool;
    XStart, XEnd, YStart, YEnd: Integer;
    DrawRect: Boolean;
    RectToDraw: TRect;
  Series1:=Chart1.AddSeries(TCandleSeries.Create(self)) as TCandleSeries;
  ChartTool1:=Chart1.Tools.Add(TFibonacciTool.Create(self)) as TFibonacciTool;
  XStart:=-1;
  XEnd:=-1;
  YStart:=-1;
  YEnd:=-1;
  DrawRect:=false;
  Chart1.Zoom.Allow:=false;
  If DrawRect then
    DrawRect := false;
    RectToDraw.Left := XStart;
    RectToDraw.Top := YStart;
    RectToDraw.Right := XEnd;
    RectToDraw.Bottom := YEnd;
  DrawRect := True;
  XStart := X;
  YStart := Y;
  Y: Integer);
  if DrawRect then
    XEnd := X;
    YEnd := Y;
    Chart1.Draw;
var i: Integer;
    tmp: Double;
  if DrawRect then
    Chart1.Canvas.Pen.Color := clBlack;
    Chart1.Canvas.Brush.Style := bsClear;
    Chart1.Canvas.Rectangle(XStart,YStart,XEnd,YEnd);
    tmp:=Chart1.Axes.Bottom.CalcPosPoint(XStart);
    for i:=0 to Series1.Count-1 do
      if Series1.XValue[i] > tmp then
        break;
    ChartTool1.StartX:=Series1.DateValues[i];
    tmp:=Chart1.Axes.Left.CalcPosPoint(YStart);
      if Series1.YValue[i] > tmp then
        break;
    ChartTool1.StartY:=Series1.CloseValues[i];
    tmp:=Chart1.Axes.Bottom.CalcPosPoint(XEnd);
        break;
    ChartTool1.EndX:=Series1.DateValues[i-1];
    tmp:=Chart1.Axes.Left.CalcPosPoint(YEnd);
        break;
    ChartTool1.EndY:=Series1.CloseValues[i-1];
