Hi there,
Is there any possibility to change a color of individual points
in FastlineSeries? I tried properties ColorEachPoint,ValueColor and
function Add(x,'',color), but they they don't work and color of point
is still the same . I'm using TeeChart7 under Delphi7.
Thanks for any ideas.
Changing points color in FastLineSeries
Hi Kamil,
Not, to speed up drawing and point handling TFastLineSeries uses the same color (SeriesColor) for all points. If you want to use diferent colors for individual points you should use the TLineSeries instead.Is there any possibility to change a color of individual points
Pep Jorge
http://support.steema.com
