Piechart, adding items to the piechart error
SPS
Post by SPS » Mon Oct 26, 2009 2:09 pm
I am getting an error when im trying to add items to the piechart. A colleague also encoutered the same problem but with a different control.
The error is:
Width must be non-negative.
When i add items to the piechart with a small width, everything works fine, but with a little bit larger objects it crashes.
Can this be fixed?
tnx in advance
Re: Piechart, adding items to the piechart error
Post by Yeray » Mon Oct 26, 2009 3:09 pm
Hi SPS,
Could you please attach here a simple example project we can run as-is to reproduce the problem here?
SPS
Post by SPS » Mon Oct 26, 2009 3:27 pm
Hi, ofcourse. Check it out.
Play a little bit with the measurements of the window, when the width is big enough it works else it doesnt.
TestCharting.rar
(11.92 KiB) Downloaded 630 times
Post by Yeray » Tue Oct 27, 2009 9:54 am
Hi SPS,
The example project you've sent is using the GSLibrary that I don't have here. Could you please send us a simple example that only uses the default libraries and the TeeChart one?
Update:
I've removed the reference and changed the chart construction and could reproduce it. I'm investigating what's happening.
SPS
Post by SPS » Tue Oct 27, 2009 10:21 am
Oops sorry for that, i'm glad you got it to work.
And tnx for taking a look at it.
Post by Yeray » Tue Oct 27, 2009 10:36 am
Hi SPS,
It seems that there is a problem in WPF that makes the application cash when having a too width mark. I've added it to the wish list to be fixed in future releases (TW16014509) but in the meanwhile maybe you could check that the labels length isn't too large. For example you could use series' marks OnGetMarksText event as follows:
        public Window1()
            tchart.Chart.Series.Add(new Steema.TeeChart.WPF.Styles.Pie());
            tchart.Chart.Aspect.View3D = false;
            tchart.Legend.Visible = false;
            tchart.Chart.Series[0].Add(4, "TESTESTETETETETEETETETETTESTESTETETETETEETETETET");
            tchart.Chart.Series[0].Add(6, "s");
            tchart.Chart.Series[0].Add(1, "s");
            tchart.Chart.Series[0].Add(9, "s");
            tchart.Chart.Series[0].Add(4, "s");
            tchart[0].GetSeriesMark += new Steema.TeeChart.WPF.Styles.Series.GetSeriesMarkEventHandler(Window1_GetSeriesMark);
        void Window1_GetSeriesMark(Steema.TeeChart.WPF.Styles.Series series, Steema.TeeChart.WPF.Styles.GetSeriesMarkEventArgs e)
            if (e.MarkText.Length > 20)
                e.MarkText = e.MarkText.Substring(0, 17) + "...";
SPS
Post by SPS » Tue Oct 27, 2009 12:40 pm
Thank you, but your workaround also works when the window is being resized?
Post by Yeray » Tue Oct 27, 2009 2:30 pm
Hi SPS,
It was an example of workaround. If your chart will be resized, the 20 constant (note that the 17 constant is the 20 without the three points) should be recalculated. This will probably be proportional to the Chart width.
SPS
Post by SPS » Fri Dec 04, 2009 2:46 pm
Is there some news about this issue, because the solution you gave me, will sometimes still create an error.
I hope it will be fixed in the next release?
Post by Narcís » Fri Dec 04, 2009 3:05 pm
Hi SPS,
No, this issue hasn't been fixed yet. When do those errors occur?
SPS
Post by SPS » Tue Dec 08, 2009 10:34 am
It depends on the information that is being shown in the piechart, with large information it will still crash even with the solution you gave me.
I see there is a new release, isnt it fixed in that release?
Post by Narcís » Wed Dec 09, 2009 10:42 am
Hi SPS,
Can you please attach a simple example project with which we can reproduce the issue here?
No, it's not listed in the release notes mentioned in the new release announcement.
SPS
Post by SPS » Tue Apr 27, 2010 1:45 pm
Hello, i was wondering if there is a solution already. It has been a couple of months ago and we need it to move on.
Post by Yeray » Wed Apr 28, 2010 3:12 pm
Hi SPS,
I'm afraid that the ticket with number [TW16014509] hasn't been closed yet. Please, be aware at this forum or subscribe to our RSS news feed for new release announcements and what's implemented on them.
