plot x AND y axis values.
cs_ech
Post by cs_ech » Thu Oct 22, 2009 7:28 pm
I need to extract x and y axis values form the database and plot them on a points graph.
The following code plots only y axis values:
points1.Add(rdr[0]);
Please advice.
Re: plot x AND y axis values.
Post by Yeray » Fri Oct 23, 2009 8:18 am
Hi cs_ech,
There are many overloads of the Add method. You are using this:
public int Add(double value)
But note that there is also this:
public int Add(double x, double y)
So, if you have your X Values at rdr[0] and your Y values at rdr[1] you could do:
points1.Add(rdr[0], rdr[1]);
Please take a look at the Tutorial8 - ADO.NET Database Access (You'll find the tutorials at TeeChart programs group)
You could also take a look at here to see how to use BindingSource, and here to see how to assign a database manually.
