Cannot Register TeeChart8.ocx in Win7
KTB
Post by KTB » Wed Oct 07, 2009 1:58 pm
When I attempt to RegSvr32 teechart8.ocx (v8.0.0.5) on a Win7 (32 & 64) OS I get the following error:
"The module c:\teechart8.ocx was loaded but the call to DLLRegisterServer failed with an error code 0x80004005."
I have tried this on 2 different machines, one 32 bit and one 64 bit with the same results.
Help!
TIA,
Ken
Re: Cannot Register TeeChart8.ocx in Win7
Post by Yeray » Wed Oct 07, 2009 2:12 pm
Hi Ken,
Please, check that you logged in with administrator privileges, disable UAC or register it through a command prompt ran "as administrator".
TomB
Post by TomB » Sat Oct 24, 2009 3:30 pm
Just a note - when you change your User Account Control (UAC), make sure you reboot your computer. Disabling the UAC will NOT take hold until a reboot.
Post by Narcís » Mon Oct 26, 2009 9:11 am
Hi TomB,
Yes, thanks. I'm not sure if it's like this in Windows 7 but Vista prompts that rebooting is needed for UAC to be disabled.
