Stacked area series
TestAlways
Stacked area series
Post by TestAlways » Mon Oct 05, 2009 6:18 pm
I am having a problem with understanding how a stacked area series when working iwth various series.
Here is an image of what I am seeing:
In the data I am working with, at a specific time (X axis) the value (y axis) will instantly go to zero.
This leaves 'holes' in the chart--everything should just shift down.
I can get this to work with two series, but do not know the logic for n series of areas.
The code is pretty simple:
procedure TForm46.UpdateChart;
  I: Integer;
  J: Integer;
  lValue: Double;
  lSrs: TChartSeries;
  Chart1.FreeAllSeries;
  for I := 0 to spnNumSeries.Value-1 do
    lSrs := CreateSeries;
    for J := 0 to spnNumPoints.Value-1 do
      lValue := GetValue(I, J);
      if lValue > 0 then
        lSrs.AddXY(J, lValue)
        lSrs.AddNullXY(J, lValue);
      if (lValue > 0) and (GetValue(I, J + 1) = 0) then
        lSrs.AddNullXY(J, 0)
A demo project is at:
http://www.tbinc.com/misc/TChartStackedAreaSeries.zip
How can I code this so that it does not have the 'holes'?
Ed Dressel
Re: Stacked area series
Post by Yeray » Tue Oct 06, 2009 10:22 am
Hi Ed Dressel,
I'm not sure to see how would you expect that to be drawn. Here it is the easiest code I can think to reproduce the problem.
And, commented, there is a line that could solve the problem for this case if you expected that those holes should be painted in the color of the area series above.
uses series;
  Chart1.View3D := false;
  Chart1.AddSeries(TAreaSeries.Create(self));
  Chart1[0].AddXY(0,10);
  Chart1[1].AddXY(0,10);
  Chart1[0].AddXY(1,10);
  Chart1[1].AddXY(1,10);
//  Chart1[1].AddXY(1,20);
  Chart1[0].AddNullXY(2,0);
  Chart1[1].AddXY(2,10);
  Chart1[0].AddXY(3,0);
  Chart1[1].AddXY(3,10);
  (Chart1[0] as TAreaSeries).MultiArea := maStacked;
  Chart1.Axes.Left.SetMinMax(0,30);
TestAlways
Post by TestAlways » Tue Oct 06, 2009 2:01 pm
If I change one number in your code, you solutions works as I would want it to:
  Chart1[1].AddXY(1,10); // <<---- changed second value  from '20 ' to '10'
And I get how to do this when working with a known number of series. But I don't know how to do this when working with a lot of series (like the demo application I posted a link to in my initial post).
Post by Yeray » Wed Oct 07, 2009 8:17 am
Hi Ed Dressel,
Take a look at this modification of your UpdateChart method that seems to work around this issue. Note that I'm simply saving where each series goes to null and I'm duplicating all the other series points over that "special" ones.
  I: Integer;
  J: Integer;
  lValue: Double;
  lSrs: TChartSeries;
  Stairs: array of TPoint; //X values will store the series index, and Y values will store the value index of the stairs
  SetLength(Stairs,0);
      if lValue > 0 then
        lSrs.AddNullXY(J, 0);
        SetLength(Stairs,Length(Stairs)+1);
        Stairs[Length(Stairs)-1] := Point(I,J);
  for I := 0 to Length(Stairs)-1 do
    for J := Stairs[I].X+1 to spnNumSeries.Value-1 do
      Chart1[J].AddXY(Stairs[I].Y, Chart1[J].YValue[Stairs[I].Y]);
TestAlways
Post by TestAlways » Wed Oct 07, 2009 3:59 pm
Nicely done--I though of something like that but wasn't sure it would work and it was not nearly so concise. (A list of objects, I like the array implementation).
For the sake of someone who might reference this, I will mention this: When working with more than two series, there is a problem because the TPoint.Y value (the index of the value in the series) will be off because the value is inserted into the list. The code change below is right towards the end:
  for I := Length(Stairs)-1 downto 0 do  //<--changed so that it counts down
Thanks for the help.
Ed Dressel
