Display a portion of Fastline series
asupriya
Post by asupriya » Thu Aug 20, 2009 3:18 am
I need to display only a part of fastline series data and let user scroll to see more. Chart pages is not a solution i am looking for. But something like a zoomed display.
Say for example, my fastline series contains data for a duration of 30 minutes with a data point at every 1/100th of a second (X axis is time and Y axis is some numeric data). By default, i get to display the whole 30-min worth of data on the chart. How can i control this default display such that user sees only the amount of data they configure (for example 5 minute duration). It is similar to zooming the duration of choice, but how i can set this by default at the chart display. Ideally, i like to have it similar to Google finance chart http://www.google.com/finance?chdnp=1&c ... DJI&ntsp=0 where user can adjust initial display of data though entire data is already read-in to the series.
I appreciate if you have a VB.Net example. Thanks
asupriya
Re: Display a portion of Fastline series
Post by asupriya » Mon Aug 24, 2009 1:02 pm
I am wondering if I can expect some help for this. Its been almost 3 days since I posted and no response yet.
thanks,
Post by Narcís » Mon Aug 24, 2009 1:49 pm
Hi asupriya,
This has already been discussed here:
http://www.teechart.net/support/viewtop ... 80&p=41366
Can you please try using the solutions suggested above?
asupriya
Post by asupriya » Tue Aug 25, 2009 12:33 am
This is exactly i am looking for. Thanks alot.
asupriya
Post by asupriya » Thu May 13, 2010 6:11 am
Little more advanced ...
How i can modify this code sample so that it works with multiple custom Y-axes that are vertically stacked as shown in the image below. I need to only show the series (and their custom y-axes) that is enclosed by the zoom resizable-rectagletool. If the user resizes the rectangletool, the series (and their custom axes) should also be changed in the zoomed chart.
Each of the curve in below image has a custom vertical axis.
Custom Y-axis zoom rectangle
5-13-2010 1-09-20 AM.png (34.73 KiB) Viewed 7763 times
Post by Yeray » Thu May 13, 2010 11:37 am
Hi asupriya,
Then you should do something similar to the example Narcís suggested in combination to the example here.
