Persistent custom axes
JuanLu
Post by JuanLu » Wed Aug 05, 2009 7:51 pm
On demo sample, there is a form (AxisCustomForm) when zoomed, an axis persists. I don´t find how to do this. Could you tell me how?
Re: Persistent custom axes
Post by Yeray » Thu Aug 06, 2009 1:49 pm
Hi JuanLu,
In the example you mention, there are 4 custom axes and they are hided with the following code:
  Dim i
  With TChart1.Axis
    For i = 0 To .CustomCount - 1
      .Custom(i).Visible = Check1.Value
    Next i
  End With
But there are also the default Left and Bottom axes visible and the loop above won't hide them. If you also want to hide them you could do this:
With TChart1.Axis
  .Left.Visible = False
  .Bottom.Visible = False
End With
JuanLu
Post by JuanLu » Thu Aug 06, 2009 2:19 pm
Hi Yeray, thanks for your reply.
I think I did a wrong question. What i want is to know how, when do zoom at any area in the chart, series 1 and 2 are changed by zoom, but series 3 mantains fixed. Is this caused by the visibility of the custom axis?
Post by Yeray » Fri Aug 07, 2009 9:04 am
Hi JuanLu,
The problem is that custom axis don't zoom automatically, you always can zoom them manually as in this example but this demo wasn't thought to show this functionality.
PS: Note that this is a delphi code but you shouldn't fins too much problems translating it.
