how to set different scale for axis(log+linear mixed)
Chen
Post by Chen » Mon Aug 03, 2009 4:29 pm
We are doing cumulative probability chart using Teechart Java version. There is a request to set mixed scale for Y-axis. 0-5% and 95%-100% is in logarithm, and 5%-95% is regular linear scale. I did not find any existing APIs can do it. If not, how to make a customized axis scale?
Thanks for your time,
Chen
Re: how to set different scale for axis(log+linear mixed)
Post by Yeray » Thu Aug 06, 2009 7:52 am
Hi Chen
I'm afraid that's not possible to make a custom (irregular) axis scale. The only solution I can think right now would be having three vertical axes (with three identical series) and you could set two of them to be logarithmic.
Here you have a very simple example. Note that you'll have to adjust manually your axes minimum and maximum in order to "connect the lines":
uses series;
var log1, log2, linear1: TFastLineSeries;
var i: Integer;
  Chart1.View3D := false;
  log1 := TFastLineSeries.Create(self);
  log2 := TFastLineSeries.Create(self);
  linear1 := TFastLineSeries.Create(self);
  with Chart1 do
    AddSeries(log1);
    AddSeries(log2);
    AddSeries(linear1);
  for i:=0 to 99 do linear1.Add(i);
  log1.DataSource := linear1;
  log2.DataSource := linear1;
  with Chart1 do
    CustomAxes.Add;
    CustomAxes.Add;
    log1.CustomVertAxis := CustomAxes[0];
    log2.CustomVertAxis := CustomAxes[1];
    CustomAxes[0].Axis.Color := log1.Color;
    Axes.Left.Axis.Color := linear1.Color;
    CustomAxes[1].Axis.Color := log2.Color;
    CustomAxes[0].StartPosition := 0;
    CustomAxes[0].EndPosition := 5;
    Axes.Left.StartPosition := 5;
    Axes.Left.EndPosition := 95;
    CustomAxes[1].StartPosition := 95;
    CustomAxes[1].EndPosition := 100;
    CustomAxes[0].Logarithmic := true;
    CustomAxes[1].Logarithmic := true;
    CustomAxes[0].SetMinMax(95, 100);
    Axes.Left.SetMinMax(5, 95);
    CustomAxes[1].SetMinMax(0,5);
  linear1.BeforeDrawValues:=SeriesBeforeDraw;
  log1.BeforeDrawValues:=SeriesBeforeDraw;
  log2.BeforeDrawValues:=SeriesBeforeDraw;
  linear1.AfterDrawValues:=SeriesAfterDraw;
  log1.AfterDrawValues:=SeriesAfterDraw;
  log2.AfterDrawValues:=SeriesAfterDraw;
procedure TForm1.SeriesBeforeDraw(Sender: TObject);
  Function SeriesRect(Series:TChartSeries):TRect;
    With result do
      Left:=Series.GetHorizAxis.IStartPos;
      Right:=Series.GetHorizAxis.IEndPos;
      Top:=Series.GetVertAxis.IStartPos;
      Bottom:=Series.GetVertAxis.IEndPos;
  With Chart1 do
    if CanClip then
      Canvas.ClipRectangle(SeriesRect( Sender as TChartSeries ));
procedure TForm1.SeriesAfterDraw(Sender: TObject);
  Chart1.Canvas.UnClipRectangle;
