how to wrap series labels
Neelam
Post by Neelam » Thu Jul 30, 2009 9:23 am
hi
I have a stacked bar cahrt. I want that labels should be wrapped when ever there is space between them.That is suppose label is "JJ HH NN". so it should show as
JJ
HH
NN
How to do this?.. thanks.
Re: how to wrap series labels
Post by Sandra » Thu Jul 30, 2009 11:12 am
Hello shikha,
I made a simple project, that I think helps, for put labels series wrap. Please see next code and check works correctly in your applicaiton.
            Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            Steema.TeeChart.Styles.Bar bar2 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            tChart1.Panel.MarginBottom = 12;
            bar.FillSampleValues();
            bar1.FillSampleValues();
            bar2.FillSampleValues();
            bar.Marks.Visible = false;
            bar1.Marks.Visible = false;
            bar2.Marks.Visible = false;
            bar.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
            for (int i = 0; i < bar.Count; i++)
                bar.Labels[i] = "JJ" + "\n"+"HH" + "\n"+"NN" + "\n";
Neelam
Post by Neelam » Thu Jul 30, 2009 11:21 am
thanks but this looks hardcoded, can u make it dynamic as the data will keep on changing and i have many labels?
Post by Yeray » Thu Jul 30, 2009 11:32 am
Hi shikha,
You could use OnGetAxisLabels to retrieve each label text and modify it as you wish. For example you could change the 'space' for '\n':
            Steema.TeeChart.Styles.Bar bar3 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar3.FillSampleValues();
            bar3.Marks.Visible = false;
            bar1.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
            for (int i = 0; i < bar1.Count; i++)
                bar1.Labels[i] = "JJ HH NN";
            tChart1.Axes.Bottom.GetAxisDrawLabel += new GetAxisDrawLabelEventHandler(Bottom_GetAxisDrawLabel);
        void Bottom_GetAxisDrawLabel(object sender, GetAxisDrawLabelEventArgs e)
            e.Text = e.Text.Replace(' ', '\n');
Neelam
Post by Neelam » Thu Jul 30, 2009 12:27 pm
thanks
AIS
Post by AIS » Thu Jul 30, 2009 2:05 pm
Should this little line work too?
tcChart.Axes.Bottom.Labels.MultiLine = true;
Post by Yeray » Thu Jul 30, 2009 2:37 pm
Hi AIS,
That's for being used with datetimes, as the help says.
Steema.TeeChart.AxisLabels.MultiLine Property help wrote:Activate Multiline Axis Labels. TeeChart will automaticall break DateTime Labels on occurence of a space " ". Use '\n' in other label types to break a line or use the SplitInLines method in the OnGetAxisLabel event.
For example:
            bar1.XValues.DateTime = true;
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "dd/MM/yyyy hh:mm:ss";
            tChart1.Axes.Bottom.Labels.MultiLine = true;
Neelam
Post by Neelam » Tue Feb 23, 2010 10:05 am
This code
e.LabelText = e.LabelText.Replace(" ", "\n")
is not working-
its giving \n within text.
That is if label is xx yy zz then using his gives xx\nyy\nzz
plesae let me know what to do.
Neelam
Post by Neelam » Tue Feb 23, 2010 10:47 am
doing by using ControlChars.NewLine or vbCrLf ( i am using vb.net, so that was the reason probably \n did not work). But now i am facing another issue. I am using data table tool and doing this is inserting empty rows in that . So for example if in my label i am giving one carriage return that in data table also its inserting one empty row , if i m giving twoe carriage return that in data table also its inserting two empty row like this-
bar1 66 88
bar2 88 99
Post by Sandra » Wed Feb 24, 2010 12:02 pm
Hello shikha,
Using last version 4 and last version 3 of TeeChart.Net, chart appears next image using this code:
Private Sub InitializeChart()
        TChart1.Aspect.View3D = False
        Dim datatool1 As Steema.TeeChart.Tools.DataTableTool = New Steema.TeeChart.Tools.DataTableTool(TChart1.Chart)
        Dim bar1 As Steema.TeeChart.Styles.Bar = New Steema.TeeChart.Styles.Bar(TChart1.Chart)
        Dim bar2 As Steema.TeeChart.Styles.Bar = New Steema.TeeChart.Styles.Bar(TChart1.Chart)
        TChart1.Header.Visible = False
        bar1.Marks.Visible = False
        bar2.Marks.Visible = False
        Dim i As Integer
        For i = 0 To bar1.Count - 1
            bar1.Labels(i) = "JJ HH"
        Next
        datatool1.RowPen.Visible = True
        datatool1.RowPen.Color = Color.Black
        datatool1.ColumnPen.Visible = True
        datatool1.ColumnPen.Color = Color.Black
        AddHandler TChart1.Axes.Bottom.GetAxisDrawLabel, AddressOf Me.Bottom_GetAxisDrawLabel
    Private Sub Bottom_GetAxisDrawLabel(ByVal sender As Object, ByVal e As Steema.TeeChart.GetAxisDrawLabelEventArgs)
        e.Text = e.Text.Replace(" ", vbLf)
Chart with v4 and v3 TeeChart.Net
Please, could you say if this is your problem?
If it isn't your problem, please you could send us a simple project, because we can reproduce your problem here.
Neelam
Post by Neelam » Wed Feb 24, 2010 12:19 pm
EXACTLY.. this is the issue i am facing!!!
Neelam
Post by Neelam » Wed Feb 24, 2010 12:24 pm
please let me know how to solve this( which you have reproduced at your end). many thanks.
Neelam
Post by Neelam » Thu Feb 25, 2010 8:11 am
Any luck? is there any solution to this?
Post by Yeray » Thu Feb 25, 2010 9:54 am
Hi shikha,
You could change the series' labels when you want, something like following:
            WrapLabels(bar1);
        private void WrapLabels(Steema.TeeChart.Styles.Bar bar)
            int maxHeight = 0;
            int tmpHeight;
                bar1.Labels[i] = bar1.Labels[i].Replace(" ", "\n");
                tmpHeight = (int)tChart1.Graphics3D.TextHeight(bar1.Labels[i]);
                if (tmpHeight > maxHeight) maxHeight = tmpHeight;
            datatool1.AutoPosition = false;
            tChart1.Panel.MarginUnits = Steema.TeeChart.PanelMarginUnits.Pixels;
            tChart1.Panel.MarginBottom = maxHeight + tChart1.Series.Count * (int)tChart1.Graphics3D.TextHeight("S");
            tChart1.Panel.MarginLeft = 15;
            tChart1.Panel.MarginTop = 10;
            datatool1.Top = tChart1.Axes.Bottom.Position + (maxHeight/3);
If you are looking for prioritary support you you may be interested in knowing of our Pro-Support service:
http://www.steema.com/licensing/support
Neelam
Post by Neelam » Wed Mar 03, 2010 12:09 pm
