strange bar width combining series with different # of data
h.hasenack
Post by h.hasenack » Mon Jul 27, 2009 8:58 am
When combining barseries and line series with different # of datapoints, the bar width becomes strange (check attached screenshots and test app). Here's a patch for that 8) :
Procedure TCustomBarSeries.DoBeforeDrawChart;
<snip>
  for t:=0 to SeriesCount-1 do
{$ifdef HH_PATCH_TC_BARWIDTH}
// THis fixes a problem when using eg mixed stacked bars and a line series. If
// the line series has more datapoints than the barseries, the bars will become
// too wide, because only other barseries are originally checkd for datacount.
// This now also checks other series with YMandatory=True
  if Series[t].Active then
    if SameClass(Series[t]) then
      Stop:=Stop or (Series[t]=Self);
      tmp:=Series[t].Count;
      if (IMaxBarPoints=TeeAllValues) or (tmp>IMaxBarPoints) then
         IMaxBarPoints:=tmp;
      Case FMultiBar of
        mbNone: INumBars:=1;
        mbSide,
        mbSideAll: begin
                     Inc(INumBars);
                     if not Stop then Inc(IOrderPos);
        mbStacked,
        mbStacked100: if NewGroup(TCustomBarSeries(Series[t]).FStackGroup) then
                        Inc(INumBars);
      if not Stop then Inc(IPreviousCount,tmp);
    end
      if Series[t].YMandatory then
           IMaxBarPoints:=tmp;
{$else}
  if Series[t].Active and SameClass(Series[t]) then
      IMaxBarPoints:=tmp;
      if FSideMargins and (tmp>0) then // 7.06
         Inc(IMaxBarPoints);
    Case FMultiBar of
      mbSide,
      mbSideAll: begin
                   Inc(INumBars);
      mbStacked,
                      Inc(INumBars);
      mbSelfStack: INumBars:=1;
    if not Stop then
  {$endif}
<snip>
PS Also the bar with becomes strange when setting eg bottomaxis min to 100, max to 1000 and adding a few irrregular datapoints like AddXY(X,Y) (110,100) (120,100) (800,100), but I have no fix for this yet as this is no problem for me at the moment :twisted: ).
TestTChart.zip
Demo app & screenshots of bar width failure
(36.71 KiB) Downloaded 217 times
Re: strange bar width combining series with different # of data
Post by Yeray » Mon Jul 27, 2009 2:19 pm
Hi Hans,
I've reproduced and added your fix to the sources so that it will be available in the next maintenance release.
Thank you.
