Patch for TeeDatetime axis with too many labels
h.hasenack
Post by h.hasenack » Fri Jul 24, 2009 11:23 am
The proposed patch influences the # of labels in an axis when very long periods are to be displayed. I have been using this patch since Tee6, i believe. Check the attachment to demonstrate the problem. (though de difference neems to be less obvious with Tee8).
Regards - Hans
Procedure TeeDateTimeIncrement( IsDateTime:Boolean;
                                Increment:Boolean;
                                var Value:Double;
                                Const AnIncrement:Double;
                                tmpWhichDateTime:TDateTimeStep);
var Year  : Word;
    Month : Word;
    Day   : Word;
 Procedure DecMonths(HowMany:Word);
   Day:=1;
   if Month>HowMany then Dec(Month,HowMany)
     Dec(Year);
     Month:=12-(HowMany-Month);
 Procedure IncMonths(HowMany:Word);
   Day:=1;
   Inc(Month,HowMany);
   if Month>12 then
     Inc(Year);
     Month:=Month-12;
 Procedure IncDecMonths(HowMany:Word);
   if Increment then IncMonths(HowMany)
                else DecMonths(HowMany);
{$ifdef HH_PATCH_TC_DATETIME}
VAR  MinNewValue:double;
{$endif}
  if IsDateTime then
    DecodeDate(Value,year,month,day);
// This loop keeps adding the desired value until the
// AnIncrement value is reached. This avoids having too many
// date labels below a chart
    if Increment then MinNewValue:=Value+AnIncrement
                 else MinNewValue:=Value-AnIncrement;
    repeat
{$endif}
    Case tmpWhichDateTime of
       dtHalfMonth   : Begin
                         if Day>15 then Day:=15
                         if Day>1 then Day:=1
                           IncDecMonths(1);
                           Day:=15;
       dtOneMonth    : IncDecMonths(1);
       dtTwoMonths   : IncDecMonths(2);
       dtThreeMonths : IncDecMonths(3);
       dtFourMonths  : IncDecMonths(4);
       dtSixMonths   : IncDecMonths(6);
       dtOneYear     : if Increment then Inc(year) else Dec(year);
      if Increment then Value:=Value+AnIncrement
                   else Value:=Value-AnIncrement;
      Exit;
    Value:=EncodeDate(year,month,day);
    until (tmpWhichDateTime<dtOneYear)
          or (Increment and (Value>=MinNewValue))
          or (not Increment and (Value<=MinNewValue));
{$endif}
  end
TestTChart.zip
Has a Date testing button on the main form
(6.08 KiB) Downloaded 234 times
Re: Patch for TeeDatetime axis with too many labels
Post by Yeray » Fri Jul 24, 2009 2:50 pm
Hi Hans,
I'm not sure to understand what is the exact problem you are noticing here. I see no difference in the result of pressing the btTestDates on your application before and after applying the changes you propose in TeeProcs.pas.
If the problem is that the labels before 1900 aren't shown, it's going to be solved with the next maintenance released as discussed here. If not, please, could you please try to explain the problem again? Maybe a picture would help us to understand it.
h.hasenack
Post by h.hasenack » Mon Jul 27, 2009 7:52 am
Ah!
I had to find out how to let it go wrong...
1) Runn testapp from ZIP
2) click testYears
3) Edit chart, change bottom axis desired increment to eg one week. All labels on the bottom axis will overlap. With my patch, they wont.
Regards - Hans
Post by Yeray » Mon Jul 27, 2009 9:29 am
Hi Hans,
Thanks for the explanation. Now I could reproduce it and see how your code solves it. I'd like you to know that your code will be present in the next v8 maintenance release.
Thank you.
