Annotation Control
gs
Annotation Control
Post by gs » Tue Jul 21, 2009 8:34 pm
Is it possible to add a control to annotation?
Sachin
Re: Annotation Control
Post by Sandra » Wed Jul 22, 2009 7:37 am
Hello Sachin,
Is not possible to add a control to annotation tool.
Please, you can say exactly what do you want to do? so we could try to find alternative solution, that works as you want in your application.
gs
Post by gs » Wed Jul 22, 2009 3:28 pm
I wanted to do something similar to that seen in the image attached for annotation
Sachin
Post by Narcís » Thu Jul 23, 2009 10:05 am
Hi Sachin,
I don't think this can be done with an annotation tool. However, you can add other controls with a TChart as their parent. For example, in the code below I used a Panel and a MessageBox. You may use other controls but can't use a System.Windows.Form in a chart as it's a top-level control.
			line1.FillSampleValues();
			tChart1.Click += new EventHandler(tChart1_Click);
			tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
		Panel myPanel;
		void tChart1_MouseMove(object sender, MouseEventArgs e)
			if (myPanel != null)
				myPanel.Dispose();
			myPanel = new Panel();
			tChart1.Controls.Add(myPanel);
			myPanel.Location = new Point(e.X, e.Y);
			Label myLabel = new Label();
			myLabel.Text = "This is the text I want to use";
			myPanel.Controls.Add(myLabel);
			Button yesBtn = new Button();
			yesBtn.Location = new Point(10, 20);
			yesBtn.Text = "Yes";
			myPanel.Controls.Add(yesBtn);
		void tChart1_Click(object sender, EventArgs e)
			DialogResult reply = MessageBox.Show(tChart1, "Tap either Yes or No", "Caption", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1);
			if ((reply == DialogResult.Yes))
				// Process Yes
				// Process No
Hope this helps!
gs
Post by gs » Mon Aug 03, 2009 8:28 pm
I was able to create a custom similar to Msgbox as mentioned by you. I want to have a line going from Msgbox to the point on Series something similar to Annotation callout how can I acheive that?
Sachin
Post by Yeray » Tue Aug 04, 2009 12:01 pm
Hi Sachin,
Taking Narcis' example, you could use OnAfterDraw event to draw a line from the desired point (in the example the sixth, valueindex 5)
        Steema.TeeChart.Styles.Line line1;
        int MouseX, MouseY;
            line1.Pointer.Visible = true;
            MouseX = 0;
            MouseY = 0;
            g.Line(line1.CalcXPos(5), line1.CalcYPos(5), MouseX, MouseY);
        Panel myPanel;
                myPanel.Dispose();
            MouseX = e.X;
            MouseY = e.Y;
            tChart1.Refresh();
                // Process Yes
                // Process No
gs
Post by gs » Tue Aug 04, 2009 8:59 pm
Thanks that works
Sachin
