Performance problems with much series
CTgmbh
Post by CTgmbh » Tue Jul 21, 2009 1:51 pm
we got charts with much series. When we scroll or zoom the chart everything is very slow. I tried to use another canvas like GDI and GDI+. It can't be the machine. I try it on a new notebook that's less then four months old (2.6GHz Core 2 Duo, 4GB Ram, ATI Radeon 3650 512MB). This doesn't help. Do you know any tricks to get better performance with a lot of series/data?
TeeChart 7.08 on BDS2006 (Delphi)
I've attached a tee file with much series and data. It looks very overloaded but that's correct (it's a non filtered selection of data).
performance.zip
TeeChart file with lots of series and data
(177.86 KiB) Downloaded 263 times
Re: Performance problems with much series
Post by Yeray » Tue Jul 21, 2009 2:07 pm
Hi Tom
It would be more helpful a tee file saved as text to allow us to see how was it exactly set:
SaveChartToFile(Chart1,'c:\tmp\performance.tee',True);
On the other hand, could you please tell us what exactly TeeChart version are you using?
Anyway, please, take a look at the Real-time Charting article. There are some tips you could use to improve your chart performance.
CTgmbh
Post by CTgmbh » Tue Jul 21, 2009 2:17 pm
Yeray wrote:It would be more helpful a tee file saved as text
Done
Yeray wrote:On the other hand, could you please tell us what exactly TeeChart version are you using?
I wrote that ;) It's TeeChart 7.08 on BDS2006 (Delphi)
Yeray wrote:Anyway, please, take a look at the Real-time Charting article. There are some tips you could use to improve your chart performance.
I will do that.
I just took a look at the documentation. I was looking if I can use TFastLineSeries instead of TLineSeries but I can't :(
Post by Yeray » Tue Jul 21, 2009 3:23 pm
Hi CTgmbh,
Done
Thank you.
Oups, Excuse me. :oops:
I will do that.
If you find any problem with it, please, don't hesitate to let us know.
CTgmbh wrote:I just took a look at the documentation. I was looking if I can use TFastLineSeries instead of TLineSeries but I can't :(
I'm not sure to understand why you can't use Fast Lines instead of Lines. Your lines don't have pointers visible, your chart isn't in 3D,...
