OnClickSeries triggers on start zooming
CTgmbh
Post by CTgmbh » Tue Jul 21, 2009 1:26 pm
we're using TeeChart 7.08 on BDS2006 (Delphi). We got a Chart with a OnClickSeries event. The user also can use zoom using the Shift key (Chart.Zoom.KeyShift = [ssShift]). But when the user starts zooming on a series the OnClickSeries event is triggered. I think TeeChart should zoom whereever the cursor is when you using the KeyShift property. Is this a bug? Is there a way to fix that?
Re: OnClickSeries triggers on start zooming
Post by Yeray » Tue Jul 21, 2009 2:40 pm
Hi CTgmbh,
I'm not able to reproduce the problem if I understood it well. I've added a line series to a chart and the following code:
  Chart1.Zoom.KeyShift := [ssShift];
procedure TForm1.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
  Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  Chart1.Title.Text.Text := 'series clicked!';
  Chart1.Title.Text.Text := 'Chart zoomed!';
  Chart1.Title.Text.Text := '';
procedure TForm1.Chart1Click(Sender: TObject);
And I can zoom using shift key wherever I start to draw the Zoom rectangle.
