Here is the sample project.
IDE is Delphi XE2 Update2. TeeChart V2011.04 source code edition is used.
Best regards.
Bug in Anit-Alias tool when using pie chart in 2D mode
Re: Bug in Anit-Alias tool when using pie chart in 2D mode
- TestProject.zip
- Test project using TGDIPlusCanvas - produces exception on Delphi XE2 Update 2
- (7.54 KiB) Downloaded 791 times
Hi marder,
The project works fine for me here using the source code version of build 2011.04.41118. I had to change some uses adding the VCLTee prefix. Find attached the project with my modifications. Does this work fine for you?
- TestProject.zip
- (74.89 KiB) Downloaded 819 times
Dear Narcis.
In the Windows Explorer "Properties" dialog the version of the Installer I downloaded yesterday is shown as "0.4455.0.0".
Under Windows installed programs I see only "Version 2011" in the column "version".
Where do I see the detailed Build version?...here using the source code version of build 2011.04.41118.
Hello marder,
You can find the build version in the release.txt in the installation folder or right-clicking on a TChart component at design-time and selecting the "About" option.
Dear Narcis.
I think there were some issues when updating the former source code version of TeeChart V2011 to the newest.
I did not uninstall TeeChart and reinstall again and the exception is gone.
Thanks for your help!
