problem with x axis time
Re: problem with x axis time
Post by Yeray » Tue Nov 29, 2016 10:06 am
Thanks for confirming it.
http://bugs.teechart.net/show_bug.cgi?id=1701
weatherdisplay
Post by weatherdisplay » Wed Dec 21, 2016 5:35 am
I see it has logged as been fixed
is there a place I can download that fix ?
Post by Yeray » Wed Dec 21, 2016 7:30 am
I'm afraid I can't tell you when the next maintenance release will be published. We'll try to publish TeeChart VCL versions quarterly.
weatherdisplay
Post by weatherdisplay » Fri Dec 23, 2016 6:08 pm
oh,..so I am not able to get a hot fix?
also I only have just realised that the version for Berlin, even the first release, has this issue on OSX (but not on windows)
am I able to use the Seattle version in Berlin?
Post by Sandra » Tue Dec 27, 2016 12:10 pm
Hello weatherdisplay,
I would like inform you if you're using the TeeChart Pro VCL/FMX binary version, the hotfix will be published for next maintenance release. But, in the case, if you're using TeeChart Pro VCL/FMX source code we can send the code that fix the bug. Do you confirm if you use source code?
Do you want use the Seattle packages in Rad Studio IDE 10.1 Berlin? If it is the case, isn't possible.
But, if you want use the Teechart Pro VCL/FMX for Rad Studio 10 Seattle you need only install the packages for that version.
Thanks in advance
weatherdisplay
Post by weatherdisplay » Fri Jan 13, 2017 6:45 pm
I used to have the source code version..but not currently
Post by Sandra » Mon Jan 16, 2017 9:41 am
Many thanks for the information. The hotfix will be published in few month with next maintenance release. As Yeray told above we try to publish a new maintenance release every quarterly.
Feel free contact us if you have any questions.
Thanks in advance
weatherdisplay
Post by weatherdisplay » Sat Apr 08, 2017 12:50 am
I have installed the latest version (April)
but I have not seen any change in behaviour for this particular bug?
weatherdisplay
Post by weatherdisplay » Sat Apr 08, 2017 12:53 am
just to clarify, its OK in VCL but not FMX (running on OSX)
Post by Yeray » Mon Apr 10, 2017 10:45 am
I've just tried the code in the ticket #1701 in TeeChart v2017.21 using RAD 10.2 and it seems to work fine for me on OSX:
Screen Shot 2017-04-10 at 12.35.13.png (44.35 KiB) Viewed 31115 times
weatherdisplay
Post by weatherdisplay » Mon Apr 10, 2017 6:38 pm
that's good to know
maybe I do not have the latest version installed for some reason
is there an easy way to find out what version is installed?
Post by Yeray » Tue Apr 11, 2017 7:02 am
weatherdisplay wrote:maybe I do not have the latest version installed for some reason
There are several ways to do this, but note that, after several TeeChart installs, you can have a TeeChart version installed as design time package but the paths could be referencing a path to another version, so the later is used to compile and run the project:
- Design-time packages: Go to "Component \ Install Packages..." and check the TeeChart packages in the list. A trick to see the full path of a package is to select it, click "Remove", read the path, and cancel the remove operation.
- Design-time packages: Open a form containing a form (or create it), right click with the mouse on the chart and read the "About" version.
- Runtime packages (Delphi): Check the library path:
- Runtime packages (C++Builder): Check the include and the library paths:
- Runtime packages (Delphi VCL): Run this code in a project:
uses TeeConst;
  ShowMessage(TeeMsg_Version);
- Runtime packages (Delphi FMX): Run this code in a project:
uses FMXTee.Constants;
- Runtime packages (C++Builder VCL): Run this code in a project:
#include <TeeConst.hpp>
- Runtime packages (C++Builder FMX): Run this code in a project:
#include <FMXTee.Constants.hpp>
More about How to set paths here.
weatherdisplay
Post by weatherdisplay » Wed Apr 12, 2017 10:53 am
HI
for the first method way
I have 924.bl installed and not 925.bpl
even though I did install the latest update
weatherdisplay
Post by weatherdisplay » Wed Apr 12, 2017 10:58 am
note, I am using Delphi Berlin
so maybe that is why the different file name?
(i.e its in the folder Delphi 24)
weatherdisplay
Post by weatherdisplay » Wed Apr 12, 2017 11:18 am
OK, it is working OK when using Tokyo
but not Berlin
(even though I installed the same version update into Berlin as well)
