I am trying to install TeeChart Pro VCL, on my Win11 PC, with Embarcadero RAD Studio 11 Alexandria.
I am getting the flowing message:
What is wrong? How to solve this issue?
TeeChart Pro - SSL support was not enabled for this installer
- ScreenHunter_0898.png (249.57 KiB) Viewed 24213 times
Re: TeeChart Pro - SSL support was not enabled for this installer
Fixed after applying recent patch on Alexandria. Or after mounting Embarcadero iso file.
- ScreenHunter_0905.png (62.39 KiB) Viewed 24203 times
Sorry, there was a problem in the site causing this problem.
It should work fine now as always.
Well.... I was a bit too optimistic...
Now I see the following message from "recompilation tool":
TeeChart files to AUTO install cannot be found.
Can anyone give me some tips on how to continue?
When starting RAD studio (or actually Delphi 11) I see the following message (see the attached picture).
Any clue?
Any clue?
- ScreenHunter_0913.png (179.11 KiB) Viewed 24190 times
- ScreenHunter_0912.png (157.94 KiB) Viewed 24196 times
1). I have uninstalled TMS, uninstalled RAD, uninstalled TeeChart.
2). Installed RAD from iso (radstudio_11_106491a.iso)
3). Installed TeeChart using (TeeChartVCLFMX-2023.38.exe)
This time the AUTO installer of TeeChart did not complain
But starting for the first time Delphi 11, I see the same message (The procedure entry point....). See attached screenshot.
Any clue?
Any clue?
- ScreenHunter_0914.png (158.83 KiB) Viewed 24136 times
To exclude issues with my PC, I have tried to install RAD 11 and TeeChart Pro on clean VMware instance of Win11.
Same result...
Same result...
- ScreenHunter_0916.png (200.1 KiB) Viewed 24134 times
OK. Managed to install TeeChart using: TeeChartVCLFMX-2022.34.exe
- ScreenHunter_0918.png (37.18 KiB) Viewed 24131 times
I see you've solved it installing the TeeChart v2022.34 as explained there.
Note the other alternatives are to use the latest IDE build with the latest TeeChart binary build, or to use the IDE build you are using and rebuild TeeChart with the source code version.
This issue is explained here.
