System.ArgumentNullException Value cannot be null. Parameter name: type
With Xamarin.Forms Version 5.0.0.1874, Version 4.8.0.1821, Version 4.8.0.1687 and Version 4.8.0.1560, graphs break on both Android and iOS. it displays if you catch the exceptions but does not render correctly: popup annotations are broken and don't show, pinch and zoom is gone, etc.
I have not tested versions prior to Version 4.8.0.1560.
Previous Related Issue
- chartviewer.PNG (70.52 KiB) Viewed 96248 times
- chart.PNG (59.04 KiB) Viewed 96248 times
Re: System.ArgumentNullException Value cannot be null. Parameter name: type
it seems that is working fine here. Do you have a simple example to reproduce it ?
Anyway, just tell to you, that we're going to upload a new nuget version package before the end of this week (compiled with the latest Xamarin.Forms version).
Pep Jorge
http://support.steema.com
just updated nugets and both exceptions still occur.
Steema.TeeChart.Tools.NearestPoint.Point doesn't seem to be updating when the NearestPoint.Change event occurs.
Also, it would be very helpful if the new point/index can be passed via the event args in the EventHandler, such as:
Then the updated NearestPoint class would be:
public class NearestPointEventArgs : EventArgs
public int Point { get; set; }
public NearestPointEventArgs() { }
public NearestPointEventArgs( int point )
Point = point;
public class NearestPoint : ToolSeries
public event EventHandler<NearestPointEventArgs> Change;
About the nearest point question.
Have you looked at the following nearest point tool example ?
https://github.com/Steema/teechart-xama ... tPointTool
We did some tests with the latest Xamarin.Forms version available and it seems that comes with a problem that might be related to the one that you writen here, so we decided to wait for the next Xamarin.Forms stable version in order to compile against this one.just updated nugets and both exceptions still occur.
Pep Jorge
yes, I checked out the nearest point tool example. I stepped through with visual studio's debugger; it's not being updated.
They just released Xamarin.Forms v5.0.0.1931, the issue still occurs
yes, you're correct. I'm able to reproduce the problem here by using the latest TeeChart for Xamarin.Forms version published.
The problem appeared since the 4.2020.9.28 version.
In order to make it work until we fix the problem ,you'd have to use the 4.2020.5.28 version.
I've already added this as an important bug here : bug 2400
We'll try to fix it as sson as possible and upload a new nuget version.
We'll also consider your apportation to add this as a new functionality for the NearestPontTool. Thank you.
Pep Jorge
Thank you for you time.
Using 4.2020.5.28, the NearestPoint tool is working again. but the exceptions still occur from above.
Yes, the exception seems to be related with Xamarin.Forms v5. Not sure if it also happens to you with older Xamarin.Forms version.
Pep Jorge
just inform to you that a new TeeChart for Xamarin.Forms Nuget version has been published, this one compiled with the latest Xamarin.Forms stable version and also includes fixes for NearestPointTool change event and also the feature you commented.
Nuget version
Nuget version
Pep Jorge
I now get a System.InvalidCastException: 'Specified cast is not valid.' error when I touch the graph.
Visual Studio v16.8.6
Xamarin.Forms v5.0.0.2012
Steema.TeeChart.NET.Xamarin.Forms v4.2021.2.18
Xamarin.Android SDK 11.1.0.26
Xamarin.iOS SDK 14.10.0.4
Note: My phone was updated to Android 11, so the app must be compiled against Android 11 in order to debug.
02-22 15:17:06.607 E/AppCenterCrashes(20449): Unhandled Exception from source=AndroidEnvironment
System.InvalidCastException: Specified cast is not valid.
at Steema.TeeChart.Tools.NearestPoint.MouseEvent (Steema.TeeChart.MouseEventKinds kind, Steema.TeeChart.Drawing.MouseEventArgs e, Steema.TeeChart.Drawing.Cursor& c) [0x0005b] in <f7c2f20fd8914905b8e049dc591c50a8>:0
at Steema.TeeChart.Chart.BroadcastMouseEvent (Steema.TeeChart.MouseEventKinds kind, Steema.TeeChart.Drawing.MouseEventArgs e, Steema.TeeChart.Drawing.Cursor& c) [0x00023] in <f7c2f20fd8914905b8e049dc591c50a8>:0
at Steema.TeeChart.TChart.OnMouseMove (Android.Views.MotionEvent e) [0x00089] in <4db77ad85a1749be9de93ae5cb78efb5>:0
at Steema.TeeChart.TChart.OnTouchEvent (Android.Views.MotionEvent e) [0x008bd] in <4db77ad85a1749be9de93ae5cb78efb5>:0
at Android.Views.View.n_OnTouchEvent_Landroid_view_MotionEvent_ (System.IntPtr jnienv, System.IntPtr native__this, System.IntPtr native_e) [0x0000f] in <b24a608f3e284c3e8fda498590205f05>:0
at (wrapper dynamic-method) Android.Runtime.DynamicMethodNameCounter.59(intptr,intptr,intptr)
**System.InvalidCastException:** 'Specified cast is not valid.'
Also, the previous exceptions still over on page creation.
We've just upload a new nuget version that includes the fix.
Please, check if the problem also happens in a new clean project.
Yes, you're correct, it was a bug which we've already fixed it.**System.InvalidCastException:** 'Specified cast is not valid.'
About this page problem I cannot reproduce the problem here using the latest versions of TeeChart for Xamarin.Forms and Xamarin.Forms.Also, the previous exceptions still over on page creation.
Pep Jorge
What I meant by "Also, the previous exceptions still over on page creation." is that the System.InvalidCastException still occurs on version 4.2021.2.25.Pep wrote: ↑Thu Feb 25, 2021 2:27 pmHello,
