How to draw multiple line without adding series?
goodsj
Post by goodsj » Tue Dec 17, 2019 1:48 am
For example, I have a sales chart by item with teechart.
I want to add break-even point line on 450.
How can I implement it? I think it would be good if you give me a sample
Thank you.
Re: How to draw multiple line without adding series?
Post by Christopher » Wed Dec 18, 2019 7:34 am
Of course - you can find the sample I refer to below in the TeeChart for .NET C# Windows Forms examples repo under the 'Feature Demo' folder. The sample shows TeeChart's canvas events which allow you to draw lines, shapes, text and images at any point of the chart at different times of its painting routine:
goodsj
Post by goodsj » Fri Dec 20, 2019 2:36 am
Thanks for answering.
I could draw line with Graphics3D, Point.
but, I couldn't set 450 its line position dynamically regardless of chart size.
Post by Christopher » Fri Dec 20, 2019 9:47 am
You can fix the point by getting the Axis to calculate the pixel value of the Axis value for you, e.g.
		private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
			var yVal = tChart1.Axes.Left.CalcPosValue(450);
			g.Pen.Color = Color.Red;
			g.HorizontalLine(tChart1.Chart.ChartRect.Left, tChart1.Chart.ChartRect.Right, yVal);
goodsj
Post by goodsj » Mon Dec 23, 2019 7:04 am
Thanks to you, we solved the problem. :D
