VC++: Error generating teechart2018.tlh
Patrick
Post by Patrick » Mon Apr 30, 2018 8:47 am
We try to update our application to current TeeChart ActiveX 2018. With TeeChart ActiveX v5 it was possible to let VC++ automatically generate the needed typelib headers like this:
#import "TeeChart5.ocx" named_guids, rename("LoadImage","TeeChartLoadImage"), rename("TextOut","TeeChartTextOut")
We tried the same with TeeChart ActiveX 2018:
#import "TeeChart2018.ocx" named_guids, rename("LoadImage","TeeChartLoadImage"), rename("TextOut","TeeChartTextOut")
but we get compile errors.
error C2259: 'TeeChart::ITeeBasePath': cannot instantiate abstract class
error C2259: 'TeeChart::ITeePoint2D': cannot instantiate abstract class
error C2365: 'TeeChart::IMapPolygon::GetPoints': redefinition; previous definition was 'data member'
error C2063: 'TeeChart::IMapPolygon::GetPoints': not a function
error C2350: 'TeeChart::IMapPolygon::GetPoints' is not a static member
This is very easy to reproduce, simply create an Win32 VC++ project and put the import statement above into stdafx.h
How can I generate the typelib headers with current TeeChart ActiveX 2018?
Patrick
Re: VC++: Error generating teechart2018.tlh
Post by Pep » Mon Apr 30, 2018 7:27 pm
Hello Patrick,
you can find all the TeeChart ActiveX 2018 typelib header file under the "\Utilities\New VC Classes" folder of the TeeChart installation.
Patrick
Post by Patrick » Fri May 04, 2018 1:23 pm
These are for MFC, right? We are using ATL though.
All the best,
Patrick
