RJRJ
Post
by RJRJ » Thu Dec 14, 2017 3:24 pm
Hi, I want to create an option where with one checkbox it is possible to see last 20 minutes of the graph.
I started with
// Graph settings
if CheckBoxGraphsLast20m.Checked then
with ChartRaw.BottomAxis do
Automatic := False;
AutomaticMaximum := True;
AutomaticMinimum := False;
Minimum := Now-(5/86400); // 5 secs
end
ChartRaw.BottomAxis.Automatic := true;
But when the checkbox is checked,
Y axes do not scale to the visible data points but keep the range concerning the full data set
Which properties/methods should I look into the get the basic effect of only showing the last x minutes of data?
Post
by Yeray » Fri Dec 15, 2017 2:27 pm
Here it is a simple example showing how to do what I understand you are trying to achieve:
uses Series, Math;
const nLastPointsToShow=10;
const oneSecond=1.0/86400.0;
var i: Integer;
tmp: Double;
const initValues=100;
Chart1.View3D:=False;
Chart1.Legend.Visible:=False;
with Chart1.AddSeries(TFastLineSeries) do
XValues.DateTime:=True;
tmp:=Now;
AddXY(tmp-(oneSecond*initValues), 100+random*10);
for i:=initValues-1 downto 0 do
AddXY(tmp-oneSecond*i, YValue[Count-1] + random*10-5);
Chart1.Axes.Bottom.LabelStyle:=talPointValue;
Chart1.Axes.Bottom.LabelsAngle:=90;
Chart1.Axes.Bottom.DateTimeFormat:='hh:mm:ss';
Timer1.Interval:=1000;
Timer1.Enabled:=True;
procedure TForm1.Timer1Timer(Sender: TObject);
with Chart1[0] do
AddXY(Now, YValue[Count-1] + random*10-5);
CheckAxes;
procedure TForm1.CheckAxes;
var i: Integer;
tmpMax, tmpMin: Double;
if CBShowLast.Checked then
Chart1.Axes.Bottom.AutomaticMinimum:=False;
with Chart1[0] do
Chart1.Axes.Bottom.Minimum:=XValue[Count-nLastPointsToShow];
Chart1.Repaint;
tmpMin:=YValue[FirstDisplayedIndex];
tmpMax:=YValue[FirstDisplayedIndex];
for i:=Chart1[0].FirstDisplayedIndex+1 to Chart1[0].LastDisplayedIndex do
tmpMin:=Min(tmpMin, YValue[i]);
tmpMax:=Max(tmpMax, YValue[i]);
Chart1.Axes.Left.SetMinMax(tmpMin, tmpMax);
end
Chart1.Axes.Bottom.Automatic:=True;
Chart1.Axes.Left.Automatic:=True;
procedure TForm1.CBShowLastClick(Sender: TObject);
CheckAxes;
RJRJ
Post
by RJRJ » Mon Dec 18, 2017 11:12 am
Thanks for the help.
I have one shared standard bottom ax and three custom Y-axes on the right. I do not fully understand the code because I had no time to read the docs (got to run to airport now), but it seems to work.
procedure TFormCoultCell2.CheckAxes(const aChart: TChart; const nLastPointsToShow: Cardinal);
var
I, Ax: Integer;
// 0 and 1 give full scale
if (nLastPointsToShow > 1) and (aChart.Series[0].Count > nLastPointsToShow) then
aChart.Axes.Bottom.AutomaticMinimum:=False;
with aChart[0] do // Refers to ?
aChart.Axes.Bottom.Minimum:=XValue[max(0, Count-nLastPointsToShow)];
aChart.Repaint;
// Loop all custom axes (they're all Y-axes on right, sharing standard bottom axe)
for Ax := 0 to aChart.CustomAxes.Count-1 do
for I:=aChart[Ax].FirstDisplayedIndex+1 to aChart[Ax].LastDisplayedIndex do
aChart.Axes[Ax].SetMinMax(tmpMin, tmpMax);
end
aChart.Axes.Bottom.Automatic:=True;
aChart.CustomAxes[Ax].Automatic := true;
Post
by Yeray » Mon Dec 18, 2017 2:53 pm
Note aChart[0] gives the first series in the Chart. So in your case, where you seem to have one series assigned to each custom axis, you should calculate the tmpMin and tmpMax using aChart[Ax] YValue
. Ie:
var
I, Ax: Integer;
with aChart[0] do // Assuming all the series have the same number of XValues
aChart.Repaint;
tmpMin:=aChart[Ax].YValue[aChart[Ax].FirstDisplayedIndex];
tmpMax:=aChart[Ax].YValue[aChart[Ax].FirstDisplayedIndex];
tmpMin:=Min(tmpMin, aChart[Ax].YValue[i]);
tmpMax:=Max(tmpMax, aChart[Ax].YValue[i]);
end
RJRJ
Post
by RJRJ » Wed Dec 27, 2017 10:16 am
OK this is what I ended up with.
I have one standard shared X axis, 3 custom Y axes, some of which may or may not have data.
var
I, S, Ax: Integer;
if (nLastPointsToShow > 1) and (aChart[0].Count-nLastPointsToShow > 0) then
with aChart[0] do // Refers to first normal series, all series have same X-data, if data lacks, will have Y=Null
aChart.Repaint;
// Loop each series
for S := 0 to aChart.SeriesCount-1 do
tmpMin := high(integer);
tmpMax := low(integer);
// If the series have positive amount of points
if (aChart[S].YValues.Count > nLastPointsToShow) then
// Loop the last n points and get min and max
for I := (aChart[S].YValues.Count-1) downto (aChart[S].YValues.Count -nLastPointsToShow) do
tmpMin:=Min(tmpMin, aChart[S].YValue[I]);
tmpMax:=Max(tmpMax, aChart[S].YValue[I]);
// Turn of automatic and apply min and max
aChart[S].CustomVertAxis.AutomaticMinimum := false;
aChart[S].CustomVertAxis.AutomaticMaximum := false;
aChart[S].CustomVertAxis.Maximum := tmpMax;
aChart[S].CustomVertAxis.Minimum := tmpMin;
end
// Set bottom and all customs to auto
RJRJ
Post
by RJRJ » Fri Dec 29, 2017 3:46 pm
How is it that with
if tmpMax >= tmpMin then
aChart[S].CustomVertAxis.Minimum := tmpMin; // This one
I get AxisException: 'Axis Maximum Value must be >= Minimum'.
Will remove the = from comparison. I added other things as well, but I still get the same exception.
if (tmpMax > tmpMin) and (assigned(aChart[S].YValues)) and (aChart[S].YValues.Count > 0) then
PS. There is a serie and axis without any data, plus 3 series and 2 axes with data.
Post
by Marc » Tue Jan 02, 2018 12:20 pm
Likely at the moment that the Maximum is being set it is less than the Minimum (the actual value of Minimum at the moment you're trying to set Maximum). You could check that and set Minimum first or use:
aChart[S].CustomVertAxis.SetMinMax(tmpMin,tmpMax);
Post
by Sandra » Tue Jan 02, 2018 12:52 pm
Hello RJRJ,
To complete the Marc's explanation, you find a simple example below:
uses Series, Math;
var i,t: Integer;
tmp: Double;
tmp:=Now;
tmp:=Now;
tmp:=Now;
Chart1.Draw();
Chart1.Axes.Left.StartPosition := 0;
Chart1.Axes.Left.EndPosition := 30;
Chart1[0].VertAxis := aLeftAxis;
Chart1[1].CustomVertAxis := Chart1.CustomAxes[0];
Chart1[2].CustomVertAxis := Chart1.CustomAxes[1];
Chart1.CustomAxes[0].StartPosition := 30;
Chart1.CustomAxes[0].EndPosition := 60;
Chart1.CustomAxes[0].Axis.Color := clRed;
Chart1.CustomAxes[1].StartPosition := 60;
Chart1.CustomAxes[1].EndPosition := 100;
Chart1.CustomAxes[1].Axis.Color := clBlue;
with Chart1[0] do
with Chart1[1] do
with Chart1[2] do
CheckAxes(Chart1,nLastPointsToShow);
procedure TForm1.CheckAxes(const aChart: TChart; const nLastPointsToShow: Cardinal);
var
I, Ax: Integer;
aChart.Repaint;
tmpMin:=aChart[Ax+1].YValue[aChart[Ax+1].FirstDisplayedIndex];
tmpMax:=aChart[Ax+1].YValue[aChart[Ax+1].FirstDisplayedIndex];
for I:=aChart[Ax+1].FirstDisplayedIndex+1 to aChart[Ax].LastDisplayedIndex do
tmpMin:=Min(tmpMin, aChart[Ax+1].YValue[i]);
tmpMax:=Max(tmpMax, aChart[Ax+1].YValue[i]);
end
Thanks in advance
