I am trying to port my FMX application from Berlin to Tokyo (C++), but I have a problem with android version when I try to add values to series at runtime (it produces access violation).
I try to make a small sample and it seems that either this one works correctly in Android (in iOS or windows works fine).
My sample is:
Add a teechart component on a form with one series and try it to fill with data at runtime with Chart1->SeriesList->FillSampleValues(20);
In Windows and iOS it displays chart correctly but not on Android.
Same application in Delphi works fine.
Is it something wrong with my installation or TeeChart or there is a bug in Tokyo?
Problem with C++ Builder Tokyo and android
Re: Problem with C++ Builder Tokyo and android
I don't get any Access Violation using the latest TeeChart Pro v2017.22. However, calling FillSampleValues for the whole SeriesList doesn't seem to populate the series in C++Builder for Android.
Instead, this works fine for me:
for (int i = 0; i < Chart1->SeriesCount(); i++) {
Chart1->Series[i]->FillSampleValues(20);
I use the same Teechart version
I have access violation when I use Add method eg:
Chart1->Series[0]->Add()
Can you try it to see if it works in your case?
Excuse us for the lack of reply here.
This is just to inform we've added it to the public tracker and found a workaround for it:
http://bugs.teechart.net/show_bug.cgi?id=2032
