After installing the newest TeeChart on my Win7/Delphi XE8 system, Delphi reports some errors at start, se attachments.
Removing and reinstalling Teechart using TeeInstall.exe does not change this.
I found that fmx220.dll is located in 4 folders on Delphi XE8,
c:\Program Files (x86)\Embarcadero\Studio\16.0\bin\fmx220.bpl
c:\Program Files (x86)\Embarcadero\Studio\16.0\bin64\fmx220.bpl
c:\Program Files (x86)\Embarcadero\Studio\16.0\Redist\win32\fmx220.bpl
c:\Program Files (x86)\Embarcadero\Studio\16.0\Redist\win64\fmx220.bpl
Filedate is 2015-03-18 which is probablay the reason for the errors.
If I rename these file Delphi complains and refuses to start.
A complete deinstallation and reinstallation of TeeChart did not change the situataion.
How can I get rid of the old fmx220.bpl ?
Gerhard Sachs
Installation problem TeeChart 2016.19.161025 VCL/FMX
- Teechart Fehler3.JPG (24.82 KiB) Viewed 13217 times
- Teechart Fehler2.JPG (28.9 KiB) Viewed 13220 times
- Teechart Fehler1.JPG (29.13 KiB) Viewed 13215 times
Re: Installation problem TeeChart 2016.19.161025 VCL/FMX
Do you have the Subscription Update 1 installed?
Note we always recommend installing all the available updates.
I have a valid Delphi XE8 license but no subscription.
Installing delphicbuilder_xe8_update1_general.exe did not solve the problem.
This is the only update that Embarcadero provides for me.
By the way I have licenses for Delphi 10 Seattle and Berlin too.
Those two versions are so slow that I returned to Delphi XE8.
So what would a Delphi subscription be good for ?
Receiving more useless software and spending a lot of time installing all components ?
I still work with VCL, not Firemonkey.
So the problem is not urgent, I simply dont want to see such errormessages after installation
Gerhard Sachs
Gerhard Sachs
Hello Gerhard,
I read you mentioned TeeInstall, but I see you own TeeChart source code version.
Are you getting this error when installing TeeChart sources, using TeeRecompile.exe?
Hello Yeray,
installing TeeChart from Sourcecode was successfiull.
First I deinstalled the old version, installed sourcecode and ran TeeInstaller.
It claimed about a missing OSX compiler which I dont have and dont need.
After that I had to reinstall ReportBuilder and now it works.
Thank you
Gerhard Sachs
Thank you
Gerhard Sachs
