Axis title text doesn't obey html format
As you can see on that picture the frame behaves correctly but the text dose not breaking the line ( <BR> tag ).
Grzegorz
Re: Axis title text doesn't obey html format
Have you set TextFormat to ttfHtml?
Chart1.Axes.Left.Title.TextFormat:=ttfHtml;
Yes I've set .
The problem appear when you switch from GDI+ to GDI render.
Grzegorz
Grzegorz
- TeeChartTestCase4.zip
- (90.06 KiB) Downloaded 901 times
Hello technicon,
Unfortunately, I can't reproduce the problem you experiencing using the code below with TeeChart Pro VCL/FMX build 2016.19.161025:
Could you check the code above and confirm your results?
Thanks in advance
Chart1->View3D = false;
Series1->FillSampleValues(100);
//CharthtmlFormat
Chart1->Axes->Left->Visible = true;
Chart1->Axes->Left->Title->Text = "Html text";
Chart1->Axes->Left->Title->TextFormat = ttfHtml;
TeeGDIPlus1->TeePanel = Chart1;
CheckBox1->Checked = true;
void __fastcall TForm1::CheckBox1Click(TObject *Sender)
if (CheckBox1->Checked)
TeeGDIPlus1->Active = true ;
TeeGDIPlus1->Active = false;
Thanks in advance
Yes I can confirm
But You have to use html tag <BR> in text eg.
GDI+ enable
GDI+ disabled
Grzegorz
Chart1->Axes->Left->Title->Text = "Html<BR>text";
Grzegorz
Hello Technicon,
Many thanks for the update information.
After reviewing that again, I would like inform you the proble is already added in TeeChart VCL bugzilla tracker. Here's the link: http://bugs.teechart.net/show_bug.cgi?id=1343.
Feel free to add your mail to the ticket CC list to be automatically notified when an update arrives.
Thanks in advance
Thanks in advance
