resize issue
SenSeo
resize issue
Post by SenSeo » Thu Jan 05, 2017 5:00 pm
I have designed a page to create a chart with responsive support.The canvas with and height is calculated based on parent's div width and height and drawn the chart. But the problem is that graph is not displayed clearly .
I have attached my sample code here
<!DOCTYPE html>
<html>
<head>
    <title>TeeChart JavaScript DOM Tooltips Example</title>
    <link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css">
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js"></script>
    <script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js"></script>
    <!-- Example, use an optional <style> .teetip {...} to customize tooltip: -->
    <style type="text/css">
        .teetip {
            margin-left: 15px !important;
            background: yellow !important;
            color: navy !important;
            font-family: Tahoma !important;
         .box-header1 {
        width: auto;
        height: auto;
        color: #444;
        display: block;
        padding: 10px;
        position: relative;
        background-color: rebeccapurple;
    </style>
    <!--[if lt IE 9]>
        <script src="../../src/excanvas/excanvas_text.js"></script>
        <script src="../../src/excanvas/canvas.text.js"></script>
    <![endif]-->
    <script src="../../src/teechart.js" type="text/javascript"></script>
var Chart1; //drawTestChart
var Chart1, tip, scaling = 0, poindex = -1;
function drawTestChart() {
    Chart1 = new Tee.Chart("canvas");
    Chart1.addSeries(new Tee.Line([5, 3, 2, 7, 1, 6, 4, 5, 1, 0, 10])).format.stroke.size = 4;
    Chart1.axes.left.format.stroke.fill = "green";
    Chart1.axes.left.title.text = "Left Axis";
    Chart1.axes.bottom.title.text = "Bottom Axis";
    Chart1.title.text = "Mouse-over Tooltips";
    Chart1.title.format.font.style = "18px Verdana";
    Chart1.series.items[0].format.stroke.fill = "darkorange";
    Chart1.series.items[0].pointer.visible = true;
    Chart1.panel.format.stroke.fill = "";
    Chart1.panel.format.shadow.visible = true;
    tip = new Tee.ToolTip(Chart1);
    tip.format.font.style = "16px Tahoma";
    tip.render = "canvas";
    Chart1.tools.add(tip);
    Chart1.series.items[0].hover.line = false;
    Chart1.series.items[0].pointer.transform = function (x, y, index) {
        var p = Chart1.series.items[0].pointer;
        if ((scaling != 0) && (poindex == index)) {
            Chart1.ctx.translate(-x, -y);
            Chart1.ctx.scale(scaling, scaling);
            p.format.fill = "red";
            p.format.fill = Chart1.series.items[0].format.fill;
    tip.onshow = function (tool, series, index) { scaling = 2; poindex = index; }
    tip.onhide = function () { scaling = 0; poindex = -1; }
    tip.ongettext = function (tool, text) { return "Text:\n" + text; }
    //changeTheme(Chart1, "minimal");
    // Chart1.draw();
    resize();
function resize() {
    var body = document.body, canvas = Chart1.canvas;
    canvas.style.width = '100%';
    canvas.style.height = '100%';
    canvas.width = canvas.width;
    canvas.height = canvas.height;
    Chart1.bounds.width = canvas.width;
    Chart1.bounds.height = canvas.height;
    Chart1.draw();
function resize1() {
        var width = 90, height = 50;  // <--- % PERCENT
    canvas.width = width * body.clientWidth / 100;
    canvas.height = height * body.clientHeight / 100;
    console.log("-----canvas width * height", canvas.width, canvas.height)
    Chart1.draw();
    </script>
</head>
<body onload="drawTestChart()" >
    <div class="box-body">
        <div class="row">
                <div class="col-md-9" style="padding-left:30px;">
                    <span class="box-title">Demo report summary</span>
                    <p>&nbsp;</p>
                    <br>
                    <div class="box-header1">
                        <div style="margin:0; padding:0; min-height:100%; height:80%; ">
                            <canvas id="canvas" style="padding-left: 0;
                 padding-right: 0;
                    margin-left: 0;
                    margin-right: 0;
                    display: block;"></canvas>
                        </div>
                    </div>
               </div>
            </div>
    </div>
</body>
</html>
Is there any way I can fix this issue?
Re: resize issue
Post by Yeray » Mon Jan 09, 2017 3:15 pm
You an use this example as reference.
In your example, resize1() function works better for me than resize(), just modify the html to include the height:
<html style="height: 100%">
and the body tag to include the onresize event and the height:
<body onload="drawTestChart()" onresize="resize1()" style="height: 100%">
