TMarksTipTool truncated with TSubChart
Eic
Post by Eic » Fri Nov 25, 2016 3:14 pm
Hello.
I made a graph consisting of two sub-graphs placed next to each other.
I use a TMarksTipTool to display information.
As the attached image shows, when I hover over the left graphic, the text appears, but it is truncated when it encroaches on the second graph. I should see "2500".
This is a small bug to fix. It would "suffice" to position it a little more to the left.
Thank you.
Re: TMarksTipTool truncated with TSubChart
Post by Yeray » Mon Nov 28, 2016 9:10 am
