I have an application with a number of lineseries in a chart plotted against multiple vertical axes (vertically stacked). Per vertical axis I would like to have a legend to show the series names linked to that axis. See the attached image example.
I can use the Legend's FirstValue and MaxnumRows properties to have the extralegends show a subset of the series, but this only works as long as the series are distributed over the Y axes in the same order is in the parent Chart's SeriesList. If for example I would like to have the 1st series on the 2nd Y axis it would not work anymore.
Solutions would be
- an event handler enabling accepting or rejecting an item in the legend
- The option to show the series in a series group
- or something showing only series attached to a particular vertical axis
I feel I need to derive a custom Legend version, but I see that this involves a lot of re-coding as many TChartLegend items are protected and few things are managed with virtual (overridable) methods.
Is there an elegant way to do this without coding?
If not: what would be the best approach to derive a custom version of the ChartLegend (to go in a Custom derivative of TExtraLegendTool)
regards, Wilfried Visser
Multiple extra legend tool to display series groups
- mutlipleextralegends.jpg (184.11 KiB) Viewed 8141 times
Re: Multiple extra legend tool to display series groups
If you only want to show the series titles (or some other text related to each series) you could use 2 TAnnotationTool(s) as in the following simple example:
If you want to also show the series symbols in the TAnnotationTool(s) then some extra code should be added to manually draw them at OnAfterDraw event. Ie:
var i, j: Integer;
Chart1.View3D:=false;
Chart1.MarginLeft:=7;
Chart1.CustomAxes.Add.EndPosition:=45;
Chart1.CustomAxes.Add.StartPosition:=55;
Chart1.Tools.Add(TAnnotationTool);
for i:=0 to 5 do
if (i mod 3 = 0) then
Chart1.AddSeries(TLineSeries)
with Chart1.AddSeries(TPointSeries) as TPointSeries do
Pointer.HorizSize:=3;
Pointer.VertSize:=3;
Pointer.Style:=psCircle;
Chart1[i].CustomVertAxis:=Chart1.CustomAxes[i mod 2];
Chart1[i].FillSampleValues;
Chart1.Draw;
for i:=0 to Chart1.CustomAxes.Count-1 do
with Chart1.Tools[i] as TAnnotationTool do
Shape.CustomPosition:=True;
Shape.Left:=Chart1.ChartRect.Left;
Shape.Top:=Chart1.CustomAxes[i].IStartPos;
Shape.AutoSize:=true;
Shape.Transparency:=0;
for j:=0 to Chart1.SeriesCount-1 do
if (Chart1[j].CustomVertAxis = Chart1.CustomAxes[i]) then
if (Text = '') then
Text:=' '+SeriesTitleOrName(Chart1[j])
Text:=Text+sLineBreak+' '+SeriesTitleOrName(Chart1[j]);
var i, j, d: Integer;
d:=9;
Chart1[j].DrawLegend(-1,Rect(Shape.Left+6,Shape.Top+d, Shape.Left+16, Shape.Top+d+4));
Inc(d,14);
I more or less already have taken this route. The tip how to dray the symbol really helps !
One final question: do you alo have a suggestion how to add a checkbox in front of the symbol that can be checked/unchecked to activate/deactivate the series?
Another question: should not the TCustomLegend tool be used for this? I tried the TCustomLegend tool but it does not seem to work properly: I do not see any text I enter in the Text property appear in the TCustomLegend grid.
regards and thanks again,
Wilfried Visser, VisserTek
You can draw it manually using DrawCheckBox function and use Chart's OnClick event to activate/deactivate the according series. Ie:wvisser wrote:do you alo have a suggestion how to add a checkbox in front of the symbol that can be checked/unchecked to activate/deactivate the series?
uses TeeTools, Series;
procedure TForm1.Chart1Click(Sender: TObject);
var i, j, n, line: Integer;
annot: TAnnotationTool;
for i:=0 to Chart1.Tools.Count-1 do
annot:=Chart1.Tools[i] as TAnnotationTool;
if annot.Clicked(Chart1.GetCursorPos.X, Chart1.GetCursorPos.Y) then
line:=(abs(Chart1.GetCursorPos.Y-(annot.Shape.Top+3)) div (abs(annot.Shape.Font.Height)+3))+1;
n:=0;
Inc(n);
if (n=line) then
Chart1[j].Active:=not Chart1[j].Active;
exit;
exit;
var i, j: Integer;
for i:=0 to 5 do
Chart1.Draw;
if (Text = '') then
var i, j, d, tmpX: Integer;
d:=9;
tmpX:=Shape.Left+20;
Chart1[j].DrawLegend(-1,Rect(tmpX,Shape.Top+d, tmpX+10, Shape.Top+d+4));
Chart1.Canvas.DrawCheckBox(Shape.Left+4, Shape.Top+d-5, Chart1[j].Active, clNone);
Inc(d,14);
That could be a different approach. Take a look at the examples under "What's New ?\Welcome!\New Chart Tools\Custom Legend Tool" in the New Features demo program shipped with the installation to see it in action, with code.wvisser wrote:should not the TCustomLegend tool be used for this? I tried the TCustomLegend tool but it does not seem to work properly: I do not see any text I enter in the Text property appear in the TCustomLegend grid.
