Hi all,
I am testing the new version of TChart Pro and made a small application with TChartEditor (in Delphi XE5). I recognized that the standard height of the axes list under "Axis" is very small so that only one axis is visible. That's a strange layout setting! Is it possible to set the height programmatically before showing the editor?
I changed the height manually but after opening the editor again I see the default behaviour. The list for manually added axes should be smaller and the list for existing axes bigger.
At the moment I use a very old version of TChart (v5.0.3) but there the axis list is correctly shown. In this version there is no separate list for manually added axes.
Thanks, Rolf
TChartEditor: ugly display of axes list
- wished layout
- ChartEditor wish.PNG (43.37 KiB) Viewed 9024 times
- default layout
- ChartEditor v2016.PNG (32.93 KiB) Viewed 9015 times
Re: TChartEditor: ugly display of axes list
Hello Rolf,
Unfortunately, the problem you're experiencing doesn't appear for me here. Anyway, I think a easy fix for you is change the RememberSize Editor in the register value from 0 to 1. To do that you should only follow the steps below:
1- Open the RegEdit (using run->regedit)
2- Go to HKEY_CURRENT_USER\SOFTWARE\Steema Software\TeeChart Pro\Editor
3- DoubleClick to RememberSize
4- Set 1 instead of 0
5- Open the editor again, the size should be changed
Hoping this helps you
Thanks in advance
Thanks in advance
Hello Sandra
Thanks for your prompt answer! I tried your suggestion and it worked but I found a solution without editing the registry: I set the height of the editor during design time high enough. Before, height and with were set to 0 (which means default values?). The default height was evidently too low to show all axes in the list.
Maybe I should set the height as a factor of PixelsPerInch to get a positive result for all screen resolutions. In my case screen resolution is 1366 x 768 and PixlesPerInch = 96 in the main window of the application.
Would your suggestion work for my customers when I deploy my application? Are these registry entries not only present if TeeChart is installed?
Thanks, Rolf
Thanks, Rolf
Hello Rolf,
The other easiest option, is go to Chart Options->Chart Editor tab and select or deselect the checkbox RememberSize.
Note you can access to the Chart options, you need only do click with right button on the chart.
The both options should be used in design time chart editor, without chart component.
Hoping this helps
Thanks in advance
The suggestion modified RememberSize, for default, is 0, that indicates the RememberSize isn't active and If you modify the editor size it shouldn't save. To change the option, you should go to the registry and change the RememberSize 0 to 1.Thanks for your prompt answer! I tried your suggestion and it worked but I found a solution without editing the registry: I set the height of the editor during design time high enough. Before, height and withd were set to 0 (which means default values?).
Sorry, I understand you work with Chart editor in design time, not with ChartEditor component. In that case, the solution is found, is a good option. Also, you can calculate the ChartEditor size according with the Screen resolution using a similar code below:The default height was evidently too low to show all axes in the list.
ChartEditor1.Height:= 300;
ChartEditor1.Width := 800;
ChartEditor1.Height := Screen.Height- ChartEditor1.Height;
ChartEditor1.Width := Screen.Width- ChartEditor1.Width;
ChartEditor1.Execute;
Thanks in advance
