My issues with the PDF are listed below:
(1) The font family is not respected but instead a default font is used in the PDF. This is a major problem when using TChart for commercial software development. A fully functional PDF export would respect all the chart properties.
(2) The left axis title is wrongly positioned in the PDF. It clashes with the left axis labels. (If the left axis is created automatically by TChart, rather than manually as here, the clashing is not as bad but still occurs. The clashing is also worse for larger font sizes. Note that the problem is only with the left axis, the bottom axis is fine.)
(3) With a large axis label font, the rightmost label on the bottom axis has been cropped.
(4) Trying to convert the PDF to JPG so I could show it as an
unit Unit1;
interface
uses
System.SysUtils, System.Types, System.UITypes, System.Classes,
System.Variants,
FMX.Types, FMX.Controls, FMX.Forms, FMX.Graphics, FMX.Dialogs,
FMX.Controls.Presentation, FMX.StdCtrls, FMXTee.Engine, FMXTee.Procs,
FMXTee.Chart, FMXTee.Series, System.UIConsts, FMX.TMSToolBar,
FMXTee.Canvas.PDF, FMXTee.Canvas;
type
TForm1 = class(TForm)
Chart1: TChart;
Button1: TButton;
private
{ Private declarations }
public
{ Public declarations }
var
Form1: TForm1;
implementation
{$R *.fmx}
var
c: TPDFCanvas;
MyRect: TRectF;
c := TPDFCanvas.Create;
try
MyRect := TRectF.Create(0, 0, Chart1.Width, Chart1.Height);
TPDFExportFormat.Draw(c, Chart1, MyRect);
with TSaveDialog.Create(nil) do
try
Filter := 'Adobe PDF files (*.pdf)|*.pdf';
DefaultExt := 'pdf';
if Execute then
c.SaveToFile(Filename);
finally
Free;
finally
c.Free;
var
I: Integer;
X, Y: Double;
with Chart1 do
// Set some chart properties
View3D := False;
BevelWidth := 0;
Shadow.Visible := False;
BottomAxis.Title.Text := 'Bottom axis title';
LeftAxis.Title.Text := 'Left axis title';
// SET BOTTOM AXIS RANGE AND TICK MARKS
Axes.Bottom.SetMinMax(0.5, 2.5);
for I := 0 to 4 do
Axes.Bottom.Items.Add(I + 0.5, FloatToStr(I + 0.5));
// SET LEFT AXIS RANGE AND TICK MARKS
Axes.Left.SetMinMax(1, 4);
for I := 0 to 3 do
Axes.Left.Items.Add(I + 1, IntToStr(I + 1));
Title.Text[0] := 'Chart Title';
Title.Font.Color := claBlue;
Title.Font.Name := 'Courier';
Title.Font.Style := [TFontStyle.fsBold];
Title.Font.Size := 36;
Subtitle.Text[0] := 'Chart Subtitle';
Subtitle.Font.Color := claRed;
Subtitle.Font.Name := 'Arial';
AddSeries(TLineSeries.Create(Self));
// WITH BIGGER FONTS, CLASHING IS WORSE
LeftAxis.Title.Font.Size := 24;
LeftAxis.LabelsFont.Size := 18;
BottomAxis.Title.Font.Size := 24;
BottomAxis.LabelsFont.Size := 18;
Legend.LegendStyle := lsSeries;
Legend.Alignment := laTop;
Series[0].LegendTitle := 'Series Legend Title';
// Create series data
for I := 0 to 20 do
X := 0.5 + I * 0.1;
Y := 3 / X;
Series[0].AddXY(X, Y);
end.
