axis labels and title overlaping for many vertical axes
Chinfot
Post by Chinfot » Wed Mar 30, 2016 9:25 am
hello
I hava two Problems,please help me.
Frist,Look the picture axis labels and title overlaping for many vertical axes.I want title on the left all the time,What should I do ?
Second,I want to draw a curve.when I set line.Smoothed = true; the Interface is not refresh. What should I do ?
Re: axis labels and title overlaping for many vertical axes
Post by Christopher » Wed Mar 30, 2016 1:14 pm
Chinfot wrote: Frist,Look the picture axis labels and title overlaping for many vertical axes.I want title on the left all the time,What should I do ?
You can use the CustomSize property, e.g.
      tChart1.Axes.Left.Title.Text = "Left Title";
      tChart1.Axes.Left.Title.Angle = 90;
      tChart1.Axes.Left.Labels.CustomSize = 100;
Chinfot wrote: Second,I want to draw a curve.when I set line.Smoothed = true; the Interface is not refresh. What should I do ?
This seems to work as expected here, e.g.
	Line line;
      line = new Line(tChart1.Chart);
      line.FillSampleValues();
Can you please post some code with which we can reproduce your problem?
Chinfot
Post by Chinfot » Thu Mar 31, 2016 9:48 am
the Line's Datasource is not fixed.when I set line.Smoothed = true; Interface cannot refresh. The following code.
timer1 = new Timer();
timer1.Interval = 2000;
timer1.Tick += new System.EventHandler(this.timer1_Tick_1);
timer1.Enabled = true;
timer1.Start();
Random rd = new Random(400);
Line line;
Timer timer1;
private void timer1_Tick_1(object sender, EventArgs e)
PointModel buffer = new PointModel();
for (int i = 0; i < 50; i++)
buffer.X = i;
if (i % 2 == 0)
buffer.Y = i + Convert.ToDouble(rd.Next(10, 50).ToString());
line.Add(buffer.X, buffer.Y);
private void simpleButton1_Click(object sender, EventArgs e)
public class PointModel
public double[] X=new double[50];
public double[] Y = new double[50];
Post by Christopher » Thu Mar 31, 2016 10:18 am
Chinfot wrote:the Line's Datasource is not fixed.when I set line.Smoothed = true; Interface cannot refresh.
Okay, I can now see the problem, thank you. The solution is to set Smoothed to true every time you make a change to the series data, e.g.
    private void timer1_Tick(object sender, EventArgs e)
        buffer.X[i] = i;
        if (i % 2 == 0)
          buffer.Y[i] = i + Convert.ToDouble(rd.Next(10, 50).ToString());
      line.Smoothed = false;
      line.DataSource = null;
Chinfot
Post by Chinfot » Tue Apr 05, 2016 3:06 am
OK,thank you!
