I tried to define the Axis title in the IDE Editor and/or programmatically.
Both are unable to write the Axis Title.
Please help.
Is this a bug?
Walter
Axis Title of DEPTH RIGHT not displayed
Re: Axis Title of DEPTH RIGHT not displayed
Hi Walter,
Code snippet below works fine for me here. Can you please check it works at your end?
Series1.FillSampleValues;
Series1.VertAxis:=aBothVertAxis;
Series1.HorizAxis:=aBothHorizAxis;
Chart1.Axes.Bottom.Title.Text:='bottom axis title';
Chart1.Axes.Top.Title.Text:='top axis title';
Chart1.Axes.Left.Title.Text:='left axis title';
Chart1.Axes.Right.Title.Text:='right axis title';
Please try a 3D chart with the DEPTH Axis right. There the Axis Ti is missing.
Hi Walter,
Depth axis is not visible by default. You need to enable it:
The title is rendered at the wrong position though so I have added it to the bug list: http://bugs.teechart.net/show_bug.cgi?id=1482
Chart1.Axes.Depth.Title.Text:='depth axis title';
Chart1.Axes.Depth.Visible:=True;
- depthaxis.png (53.6 KiB) Viewed 19960 times
