Hello
Someone can help me to fix the text on axis ?, the label is cut.
I can't enlarge the graph.
I use the method AddXY to write the graph.
I appends the date and time in the parameter "label".
thanks for your help
bye
Label on X axis is cut
- Capture.PNG (31.5 KiB) Viewed 13920 times
Re: Label on X axis is cut
Have you tried to add some offset on the bottom axis minimum/maximum? Ie:
TChart1.Axis.Bottom.MinimumOffset = 10
TChart1.Axis.Bottom.MaximumOffset = 10
Hello
Don't work with
but i use this method
TChart1.Panel.MarginBottom and it's ok now
Thanks for help
Don't work with
Thanks for help
- Capture.PNG (29.43 KiB) Viewed 13885 times
I'm glad to hear you found how to make it work as you wish.
