We have used the Latest Version of TeeChart with our Project and we are getting following visible differences as shown in attached screenshots.
There are two visible differences:
1] Axis Labels Font Size gets increased.
2] Axis Border gets Invisible.
Please let us know how to resolve them.
Note: We didn't change anything in our project. We checked the same with older TeeChart Version again which is working fine.
TeeChart New Version Integration Issue
- With Latest (Dec-15) Version of TeeChart
- Acc Latest.png (42.94 KiB) Viewed 13506 times
- Guru
Re: TeeChart New Version Integration Issue
Using TeeChart.dll 4.1.2015.12161, the .NET 3.5 version shipped with the latest release, running the following code:
gives me the following chart:
this is because of changes to the default theme. To change the theme back to that of previous versions, you can use:
which gives the following:
tChart1.Series.Add(typeof(Candle)).FillSampleValues();
tChart1.CurrentTheme = ThemeType.Opera;
We added following code to our project and it changed whole appearance of the chart.
Attaching the screenshot for your reference. Please check previously attached screenshot for our original Chart Appearance.
- Guru
Yes, that is the expected behaviour.Quant wrote:We added following code to our project and it changed whole appearance of the chart.![]()
May I suggest, then, that you either:
1) change the theme and then apply all the color/font etc. changes you wish
2) do not change the theme, but specify *all* the color/font etc. changes you wish
