Thanks a lot,
for helping us to find the problem while we were searching for a solution.
For our real chart we were using two areas (Line / Area). We just remove the Area and add some lines code to the end of doDrawLine() function in Line area:
var gradient = a.createLinearGradient(0, a.canvas.height, 0, 0);
gradient.addColorStop(0, "rgba(0, 175, 240, 0)");
gradient.addColorStop(1, "rgba(0, 175, 240, 0.3)");
a.fillStyle = gradient;
var lastPointX = this.chart.axes.bottom.calc(this.maxXValue());
a.lineTo(lastPointX, a.canvas.height);
a.lineTo(0, a.canvas.height);
a.fill();
As a result we have a good line/area chart with perfect gradient doesn't matter if we change the min/max:
- Untitled.png (88.51 KiB) Viewed 11569 times
Best regards!
