Please find attached a screen image of my silverlight application.
How do I add a black line at the bottom and the right side of the image bar?
Also, when I export the graph to PNG the whole image bar is coloured black?
And last, each stacked image bar represents a depth interval with a top depth and bottom depth, how do I add the last bottom depth on the bottom of the left axis?
Environment:
Windows 7, VS 2012
.NET 4.0 & Silverlight 5.0
TeeChart version 4.1.2015.8063
Thanks & Regards
Imagebar
Imagebar
- Screen image from my appliation
- steema-imagebar.jpg (274.5 KiB) Viewed 5071 times
- Guru
Re: Imagebar
Which version of TeeChart.Silverlight.dll are you using?
It seems that image placement is not pixel perfect, I'm afraid. The best I can offer you is to set this pen to invisible, e.g.cjherasmus wrote:How do I add a black line at the bottom and the right side of the image bar?
ImageBar bar = new ImageBar(tChart1.Chart);
bar.FillSampleValues();
bar.Pen.Visible = false;
This works with the latest public version and the standard ImageBar series above. The image will need to be added to your project, however, e.g.cjherasmus wrote: Also, when I export the graph to PNG the whole image bar is coloured black?
I'm sorry, but I'm not entirely sure I can visualize your problem here. Could you please give me a few more details to help me?cjherasmus wrote: And last, each stacked image bar represents a depth interval with a top depth and bottom depth, how do I add the last bottom depth on the bottom of the left axis?
