Markus
Post
by Markus » Wed Oct 28, 2015 3:10 pm
I am playing a little bit around with the LoadMap function because we want to extend our tool to deal with GIS data. The funtion works well but I guess there's a bug in the Code right here:
{$IFDEF CLR}
ReadSHPHeader(ShpStream,SHPHeader);
{$ELSE}
ShpStream.ReadBuffer(SHPHeader,SizeOf(TSHPHeader));
{$ENDIF}
VerifySignature(SHPHeader.FileCode);
{$IFDEF CLR}
ReadSHPHeader(ShxStream,SHPHeader);
{$ELSE}
ShxStream.ReadBuffer(SHPHeader,SizeOf(TSHPHeader));
{$ENDIF}
As you may see, the code is doubled. That leads to a false record number in the following code
NumRecords:=RecordCount(SHPHeader);
Is this a known issue? The resulting map Chart then mirrors that error as one can see, when you make the legend visible or just have a look at the data. There are too many data rows in the map.
Markus
Post
by Yeray » Fri Oct 30, 2015 12:16 pm
Hello Markus,
Markus wrote:As you may see, the code is doubled.
Not exactly doubled. The first part loads the shp while the second part loads the shx.
Markus wrote:or just have a look at the data. There are too many data rows in the map.
Looking at the data tab in the demo, the shapes don't look doubled there:
- europe.png (157.72 KiB) Viewed 5096 times
Markus
Post
by Markus » Sat Oct 31, 2015 12:04 pm
your right! My fault! But I still have the problem that when I load a shp file, the data rows are multiple. I attached a sample project with a specific shp file, where you can see the effect. Is the shape file corrupt?
Thanks for your Support!
Markus
- GISTest.zip
- (231.93 KiB) Downloaded 424 times
Post
by Yeray » Mon Nov 02, 2015 11:17 am
This shapefile has 16 records; some records have a single shape but some of them have multiple shapes. That's why there are more rows in the "Data" grid than records in the shp file.
The "Value" field on the "Data" grid represents the ZValues array used to give a color to each shape.
