How to avoid overlapping x-axis labels
opdr
Post by opdr » Wed Oct 07, 2015 5:52 am
I have a problem with x-axis labels that overlap and makes a mess in the presentation.
Does anyone know how to avoid this problem? (see attachment for example).
In earlier versions, for Delphi7, this was not an issue.
Ole Petter
Sample overlapping x-axis labels
Re: How to avoid overlapping x-axis labels
Post by Yeray » Wed Oct 07, 2015 11:39 am
Hello Ole Petter,
Take a look at the discussion here, where the same issue is addressed.
If you still find problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem.
It would help if you could specify between what 2 versions have you noticed the behaviour changed.
opdr
Post by opdr » Thu Oct 08, 2015 5:36 am
Thanks Yeray,
I'll try out the suggested solution you have pointed out on the referred topic.
I'll see if I can give labels for each series an offset within some given limits.
That could be a solution for several series.
Ole Petter
