Series Chart color and Legend Chart color.
MVBobj
Post by MVBobj » Wed Aug 05, 2015 12:45 pm
If I set the series color manually, how do I set the associated color in the little box in the legend to the same color?
Re: Series Chart color and Legend Chart color.
Post by Narcís » Wed Aug 05, 2015 1:08 pm
I'm not sure about which is your exact problem. If I run the code snippet below bar's legend symbol becomes red. Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
uses Series;
  Chart1.AddSeries(TBarSeries.Create(Self)).FillSampleValues;
  Chart1[0].Color:=clRed;
MVBobj
Post by MVBobj » Wed Aug 05, 2015 1:59 pm
Enclosed is a simple project. DelphiXE7 Win7Pro64Bit
In your FormCreate, the chart hasn't displayed yet.
In my project - the chart and legend with legend colors are visible and when you click Button1, the 3 series are loaded, their colors set and displayed and the legend colors remain as they were on startup!
How do I reset the legend colors?
SeriesLegend.zip
(100.22 KiB) Downloaded 1048 times
Post by Narcís » Wed Aug 05, 2015 2:20 pm
Your code is setting specific point color but not the general color for the series. You should use TChartSeries.Color property instead:
procedure TForm2.Button1Click(Sender: TObject);
var
  clrBar1, clrBar2, clrBar3: TColor;
  clrBar1 := clWebLightCyan;
  clrBar2 := clWebLightSteelBlue;
  clrBar3 := clWebLemonChiffon;
  Chart[0].Color:=clrBar1;
  Chart[0].Add(7, '01/04/2004', clrBar1);
  Chart[0].Add(17,'01/11/2004', clrBar1);
  Chart[0].Add(6, '01/18/2004', clrBar1);
  Chart[0].Add(12,'01/25/2004', clrBar1);
  Chart[0].Add(5, '02/01/2004', clrBar1);
  Chart[0].Add(7, '02/08/2004', clrBar1);
  Chart[0].Add(14,'02/15/2004', clrBar1);
  Chart[0].Add(4, '02/22/2004', clrBar1);
  Chart[0].Add(12,'03/01/2004', clrBar1);
  Chart[0].Add(9, '03/08/2004', clrBar1);
  Chart[0].Add(17,'03/15/2004', clrBar1);
  Chart[0].Add(2, '03/22/2004', clrBar1);
  Chart[0].Add(5, '03/29/2004', clrBar1);
  Chart[0].Add(10,'04/06/2004', clrBar1);
  Chart[0].Add(6, '04/13/2004', clrBar1);
  Chart[1].Color:=clrBar2;
  Chart[1].Add(17, '01/04/2004', clrBar2);
  Chart[1].Add(27,'01/11/2004', clrBar2);
  Chart[1].Add(16, '01/18/2004', clrBar2);
  Chart[1].Add(22,'01/25/2004', clrBar2);
  Chart[1].Add(15, '02/01/2004', clrBar2);
  Chart[1].Add(17, '02/08/2004', clrBar2);
  Chart[1].Add(24,'02/15/2004', clrBar2);
  Chart[1].Add(14, '02/22/2004', clrBar2);
  Chart[1].Add(22,'03/01/2004', clrBar2);
  Chart[1].Add(19, '03/08/2004', clrBar2);
  Chart[1].Add(27,'03/15/2004', clrBar2);
  Chart[1].Add(12, '03/22/2004', clrBar2);
  Chart[1].Add(15, '03/29/2004', clrBar2);
  Chart[1].Add(20,'04/06/2004', clrBar2);
  Chart[1].Add(16, '04/13/2004', clrBar2);
  Chart[2].Color:=clrBar3;
  Chart[2].Add(27, '01/04/2004', clrBar3);
  Chart[2].Add(37,'01/11/2004', clrBar3);
  Chart[2].Add(26, '01/18/2004', clrBar3);
  Chart[2].Add(32,'01/25/2004', clrBar3);
  Chart[2].Add(25, '02/01/2004', clrBar3);
  Chart[2].Add(27, '02/08/2004', clrBar3);
  Chart[2].Add(34,'02/15/2004', clrBar3);
  Chart[2].Add(24, '02/22/2004', clrBar3);
  Chart[2].Add(32,'03/01/2004', clrBar3);
  Chart[2].Add(29, '03/08/2004', clrBar3);
  Chart[2].Add(37,'03/15/2004', clrBar3);
  Chart[2].Add(22, '03/22/2004', clrBar3);
  Chart[2].Add(25, '03/29/2004', clrBar3);
  Chart[2].Add(30,'04/06/2004', clrBar3);
  Chart[2].Add(26, '04/13/2004', clrBar3);
Actually, you could even remove color setting for each point:
  Chart[0].Color := clWebLightCyan;
  Chart[1].Color := clWebLightSteelBlue;
  Chart[2].Color := clWebLemonChiffon;
  Chart[0].Add(7, '01/04/2004');
  Chart[0].Add(17,'01/11/2004');
  Chart[0].Add(6, '01/18/2004');
  Chart[0].Add(12,'01/25/2004');
  Chart[0].Add(5, '02/01/2004');
  Chart[0].Add(7, '02/08/2004');
  Chart[0].Add(14,'02/15/2004');
  Chart[0].Add(4, '02/22/2004');
  Chart[0].Add(12,'03/01/2004');
  Chart[0].Add(9, '03/08/2004');
  Chart[0].Add(17,'03/15/2004');
  Chart[0].Add(2, '03/22/2004');
  Chart[0].Add(5, '03/29/2004');
  Chart[0].Add(10,'04/06/2004');
  Chart[0].Add(6, '04/13/2004');
  Chart[1].Add(17, '01/04/2004');
  Chart[1].Add(27,'01/11/2004');
  Chart[1].Add(16, '01/18/2004');
  Chart[1].Add(22,'01/25/2004');
  Chart[1].Add(15, '02/01/2004');
  Chart[1].Add(17, '02/08/2004');
  Chart[1].Add(24,'02/15/2004');
  Chart[1].Add(14, '02/22/2004');
  Chart[1].Add(22,'03/01/2004');
  Chart[1].Add(19, '03/08/2004');
  Chart[1].Add(27,'03/15/2004');
  Chart[1].Add(12, '03/22/2004');
  Chart[1].Add(15, '03/29/2004');
  Chart[1].Add(20,'04/06/2004');
  Chart[1].Add(16, '04/13/2004');
  Chart[2].Add(27, '01/04/2004');
  Chart[2].Add(37,'01/11/2004');
  Chart[2].Add(26, '01/18/2004');
  Chart[2].Add(32,'01/25/2004');
  Chart[2].Add(25, '02/01/2004');
  Chart[2].Add(27, '02/08/2004');
  Chart[2].Add(34,'02/15/2004');
  Chart[2].Add(24, '02/22/2004');
  Chart[2].Add(32,'03/01/2004');
  Chart[2].Add(29, '03/08/2004');
  Chart[2].Add(37,'03/15/2004');
  Chart[2].Add(22, '03/22/2004');
  Chart[2].Add(25, '03/29/2004');
  Chart[2].Add(30,'04/06/2004');
  Chart[2].Add(26, '04/13/2004');
MVBobj
Post by MVBobj » Wed Aug 05, 2015 3:24 pm
Excellent!
Thank you.
emwamin
Post by emwamin » Fri Oct 02, 2015 10:01 am
This solution does not work for me. Not only that the legend does not have correct text color, it is not possible to change it with the Toolbox. I am using ErrorBar serie.
I am using Tee Chart Pro v2015.14.150120. I have to add that this error introduced in the latest release. I have not changes my coding after updating the Tee Chart.
Procedure myProcedure;
var
   MySeries: TErrorBarSeries;
  CL: TColor;
Begin
   CL := clRed;
Chart1.FreeAllSeries(nil);
Chart1.Legend.Visible := true;
Chart1.Legend.FontSeriesColor := true;
Chart1.Legend.LegendStyle := LsSeries;
MySeries := TErrorBarSeries.Create( Self );
Chart1.AddSeries( MySeries );
MySeries.ParentChart := Chart1;
MySeries.Title := 'myTitle';
MySeries.Color := CL;
MySeries.ErrorStyle := essTopBottom;
MySeries.AddErrorBar(indx,valAverage,valSEM,'Text1',CL);
Here are the images from the previous version and the new version of Tee chart:
As you can see "Early" and "Late" do not have the same color as the bars.
Please adivise how to solve this issue.
BR
emwamin
Post by Yeray » Fri Oct 02, 2015 1:41 pm
Give it a try at the latest version, v2015.16. I could reproduce the problem with v2015.14 but not with the latest version.
emwamin
Post by emwamin » Wed Oct 07, 2015 7:47 am
I have upgraded to v2015.16 and can confirm that the problem is solved.
Thanks a lot.
BR
emwamin
