ROTATED BOTTOM AXIS LABELS INCORRECTLY POSITIONED
KJT
Post by KJT » Sat Dec 13, 2014 11:52 pm
In TChart version 8.02 I rotated bottom axis labels and they looked correct as per attachment. In version 2013 they are not correctly placed as per second attachment. In version 2014, the same problem exists. Can you advise what I need to do to get the desired label placement?
Incorrect Bottom Axis Labels
TChart Ver 2013 Axis Labels Rotated Wrong.PNG (11.23 KiB) Viewed 8700 times
Correct Bottom Axis Labels
TChart Ver 8.02 Axis Labels Rotated Correct.PNG (14.4 KiB) Viewed 8693 times
Re: ROTATED BOTTOM AXIS LABELS INCORRECTLY POSITIONED
Post by Yeray » Mon Dec 15, 2014 1:11 pm
This is an issue we are already aware of as you can see here:
http://bugs.teechart.net/show_bug.cgi?id=947
KJT
Post by KJT » Tue Dec 16, 2014 9:32 am
Thanks Yeray, is there any chance this could be fixed in the next version? It is significant for us to have this in our next release. Rolling back to the early release of 2013 wont work for our code is there are GDI+ issues.
KJT
Post by KJT » Sun Feb 08, 2015 12:35 am
Is there a way to owner draw the bottom axis labels?
Post by Yeray » Mon Feb 09, 2015 1:36 pm
Excuse us for the delay here.
I'll increment the ticket priority.
Post by Yeray » Wed Jun 03, 2015 8:27 am
Forgot to say here the ticket was closed the 30th April 2015 but the changes were applied on the sources the 11th March 2015, so the v2015.15 published the 20th April 2015 includes the fix.
