TeeChart2014.0.0.2 in Japanese system
Micro
Re: TeeChart2014.0.0.2 in Japanese system
Post by Micro » Mon Apr 20, 2015 10:54 am
We've tested also on other machines and we still get the problem.
I attached a picture with the stack trace of the dump file from our demo project crash.
Post by Marc » Tue Apr 21, 2015 1:29 pm
The cause of the problem has been identified and we are working on a fix. It's taking some time to identify a working solution as what seems to be required on Japanese systems is contradictory to what is suitable on other systems. We'll make a test version available when we get to a viable proposal.
Post by Yeray » Thu Apr 23, 2015 10:35 am
I'm sending a new pre-release version of the ocx to the mail account you have registered in this forum.
Micro
Post by Micro » Mon Apr 27, 2015 3:01 pm
Thanks, it's working.
Should we use the sent ActiveX control or there will be another release soon?
Post by Yeray » Tue Apr 28, 2015 6:58 am
Micro wrote:Thanks, it's working.
Good news! I'm glad to hear that.
Micro wrote:Should we use the sent ActiveX control or there will be another release soon?
There was a maintenance release recently published. I'm afraid I can't tell you when the next one will be published.
If that pre-release ocx we sent you works fine for you, there's no objection on our part for you to use it.
