Vertical Line Alignment
Quant
Post by Quant » Fri Mar 27, 2015 12:05 pm
We are facing performance issue while aligning vertical line (i.e. Color Line Tool, AXIS=Bottom) in two charts as shown in attached image.
Vertical Line not Aligned while mouse is moving
Vertical Line 1.JPG (24.75 KiB) Viewed 7841 times
Vertical Line aligned while mouse is stopped at any location
Vertical Line 2.JPG (25.29 KiB) Viewed 7849 times
While moving mouse, vertical line in second chart lags behind vertical line of first chart.
Please help us to resolve this issue.
Re: Vertical Line Alignment
Post by Narcís » Fri Mar 27, 2015 12:25 pm
Hi Quant,
Is this the same problem you posted here? Otherwise, could you please attach a Short, Self Contained, Correct (Compilable), Example?
Quant
Post by Quant » Mon Mar 30, 2015 6:06 am
Please find attached sample code of vertical line alignment.
Vertical Line.zip
(20.09 KiB) Downloaded 752 times
Post by Christopher » Mon Mar 30, 2015 9:55 am
Quant wrote:Please find attached sample code of vertical line alignment.
Vertical Line.zip
I think this issue is identical to the one you posted here, and so the solution to it is the one I posted in that thread.
