HI,
I have an application that charts stock prices, on my desktop it looks perfect, as it does on all my colleagues desktops, please see desktop.jpg
However on my laptop or when a projector is connected to a PC changes size. I have tried locking the aspect ratio, preventing re-sizing etc nothing seems to work, pls see laptop.jpg
I would be grateful for any suggestions
Barry
Chart re-sizing on different machines
- Laptop.jpg (160.35 KiB) Viewed 5129 times
- desktop.jpg (131.25 KiB) Viewed 5090 times
Re: Chart re-sizing on different machines
I see the chart doesn't take all the form width.
Can you reproduce the problem in a new simple project? If so, could you please send it to us?
I think I have sorted it, it looks like the chart does not keep its aspect ratio on different screen sorts so on a 1600 * 1200 screen it looks fine. However on a 1920*1080 screen it does not. What I had to do is work out the width of the form and then size the chart Dynamical using
where
Have not tested it on all screens but on 2 or 3 seems ok.
LeftAlignCharts([Chart1,Chart2],8,Form1.Width - 28);
procedure TForm1.LeftAlignCharts(Const Charts: Array of TCustomChart; aLeft: Integer; aWidth: Integer);
// This procedure align's two charts on the form
var i: Integer;
for i := Low(Charts) to High(Charts) do
With Charts[i] do
Left := aLeft;
MarginLeft := 0;
Width := aWidth;
Axes.Left.TitleSize := 15;
Axes.Left.LabelsSize := 100; // Needs to be big as numbers can run to millions
Axes.Left.LabelsAlign := alDefault;
Marginright := 1; // This is in % not pixels
I'm glad to hear you found how to make it work fine.
If you still find problems with it, don't hesitate to let us know.
