Left axis label vertical position
johnnix
Post by johnnix » Tue Nov 25, 2014 10:23 am
I believe that with the latest 2014 version there has been a change in the starting position of the Y axis label. As you can see from the images in earlier versions the label was centered to the middle of the axis length but now it looks like it starts from that point.
Re: Left axis label vertical position
Post by Yeray » Tue Nov 25, 2014 11:05 am
I've tried the following code in a new empty application:
uses Chart, Series, TeeConst, TeCanvas;
var Chart1: TChart;
  Caption:=TeeMsg_Version;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPointSeries);
  Chart1.Axes.Left.Title.Text:='Depth';
  Chart1.Canvas:=TTeeCanvas3D.Create;
In TeeChart v2014.12 indeed, the label looks a bit displaced:
But in the current internal sources, it looks correct again:
So I'd expect this to be fixed with the next maintenance release.
johnnix
Post by johnnix » Thu Nov 27, 2014 8:37 pm
Ok, thank you for your reply.
