Two annotations for cursor tool
anauta2014
Post by anauta2014 » Thu Nov 20, 2014 9:07 am
Currently cursor tool has only one annotation on the bottom axis. Is it possible to have two annotations one on the bottom axis and the second on the left axis?
With bets regards
Vladimir
Re: Two annotations for cursor tool
Post by Yeray » Thu Nov 20, 2014 10:55 am
Hi Vladimir,
You can add as many TAnnotationTools as you want and calculate their position at the TColorLineTool OnDragLine event.
anauta2014
Post by anauta2014 » Thu Nov 20, 2014 12:46 pm
Hi Yeray
I know, I can add, but as cursor tool has one X-annotation tool, for symmetry can be the second Y-annotation.
With bets regards
Vladimir
Post by Yeray » Thu Nov 20, 2014 2:16 pm
Hi Vladimir,
Sorry, I misread it and understood you were talking about the TAnnotationTool in the TColorLineTool, while you clearly mentioned it's about the TAnnotationTool on the TCursorTool.
http://bugs.teechart.net/show_bug.cgi?id=1019
anauta2014
Post by anauta2014 » Fri Feb 13, 2015 3:03 pm
Hi Yeray
As I can this issue is not fixed yet.
Would you like to tell, how this can be fixed?
With bets regards
Vladimir
Post by Yeray » Fri Feb 13, 2015 3:57 pm
Hi Vladimir,
Note this is a feature request to be implemented, more than a bug to be fixed.
I'm afraid you are right, this hasn't been implemented yet, but since the same result can already be done without much effort with the current set of tools, I wouldn't give this a much elevated priority.
jens.mertelmeyer
Post by jens.mertelmeyer » Mon Feb 16, 2015 8:38 am
Yeray wrote:since the same result can already be done without much effort
Exactly. I did it like this:
procedure TForm8.cursorToolChange(
	Sender: TCursorTool;
	x, y: Integer;
	const XValue, YValue: Double;
	Series: TChartSeries;
	ValueIndex: Integer);
	annotationTool.Top := Y - (annotationTool.Height div 2);
	annotationTool.Text := YValue.ToString();
cursorTool and annotationTool.png (13.24 KiB) Viewed 16800 times
