Legend with Continous = true and formatting of legind text
1) How do I get the legend to span the entire ChartRect.Height? as shown in the attached graphs, it only spans the top of the chart?
2) How do I format the legend text so that it becomes - for instance - 128,6 instead of 128,577 ??
- unknown.JPEG (180.93 KiB) Viewed 20157 times
Re: Legend with Continous = true and formatting of legind text
Hi Friis,
1. What about something like this?
2. You can modify legend text format in the GetLegenText event, for example:
tChart1.Series.Add(new ColorGrid()).FillSampleValues();
tChart1.GetLegendRect += tChart1_GetLegendRect;
tChart1.Legend.Symbol.Continous = true;
tChart1.Legend.Font.Size = 14;
void tChart1_GetLegendRect(object sender, GetLegendRectEventArgs e)
Rectangle chartRect = this.tChart1.Chart.ChartRect;
e.Rectangle = new Rectangle(e.Rectangle.Left, chartRect.Top, e.Rectangle.Width, chartRect.Height);
void tChart1_GetLegendText(object sender, GetLegendTextEventArgs e)
double tmp = Convert.ToDouble(e.Text);
e.Text = tmp.ToString("0.000");
1) This does not solve the problem - try to test the code I have made below on your system - can you reproduce the problem?
2) Thank you - I will use this
Make3DGraph();
public void Make3DGraph()
try
this.tChart1.Series.Clear();
this.tChart1.Series.RemoveAllSeries();
this.tChart1.Dock = DockStyle.Fill;
this.tChart1.BackColor = Color.White;
this.tChart1.Walls.Back.Gradient.Visible = false;
this.tChart1.Walls.Back.Color = Color.White;
this.tChart1.Walls.Bottom.Gradient.Visible = false;
this.tChart1.Walls.Bottom.Color = Color.White;
this.tChart1.Panel.Gradient.Visible = false;
this.tChart1.Panel.Color = Color.White;
this.tChart1.Aspect.View3D = false;
this.tChart1.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
this.tChart1.Axes.Left.Automatic = true;
this.tChart1.Axes.Bottom.Automatic = true;
this.tChart1.Axes.Left.Title.Caption = "";
this.tChart1.Axes.Bottom.Title.Caption = "";
this.tChart1.Header.Text = "";
this.tChart1.Header.Font.Size = 14;
this.tChart1.Legend.VertSpacing = 0;
this.tChart1.Legend.Symbol.Width = 100;
this.tChart1.Legend.Transparent = false;
this.tChart1.Legend.Symbol.DefaultPen = false;
this.tChart1.Legend.Symbol.Continous = true;
this.tChart1.Legend.Symbol.Pen.Color = Color.White;
this.tChart1.Legend.Symbol.Pen.Width = 1;
this.tChart1.Legend.DividingLines.Visible = false;
this.tChart1.Legend.Symbol.Width = 50;
this.tChart1.Legend.Symbol.Squared = true;
this.tChart1.Legend.Visible = true;
this.tChart1.Legend.Shadow.Visible = true;
this.tChart1.Legend.Font.Size = 14;
this.tChart1.Axes.Left.Title.Text = "Power / MW";
this.tChart1.Axes.Left.Title.Font.Size = 14;
this.tChart1.Axes.Bottom.Title.Text = "Q / MJ/s";
this.tChart1.Axes.Bottom.Title.Font.Size = 14;
Steema.TeeChart.Styles.ColorGrid ColorGridSeries1 = new Steema.TeeChart.Styles.ColorGrid(tChart1.Chart);
this.tChart1.Series.Add(ColorGridSeries1);
ColorGridSeries1.Pen.Visible = false;
ColorGridSeries1.Title = "surface1";
ColorGridSeries1.UseColorRange = false;
ColorGridSeries1.UsePalette = true;
ColorGridSeries1.IrregularGrid = true;
ColorGridSeries1.CenteredPoints = true;
for (double x = 0; x < 10; x += 0.1) // = 10 rows
for (double z = 0; z < 10; z += 0.1) // = 10 columns
ColorGridSeries1.Add(x, x*z, z);
Color[] ColorPalette = new Color[100];
double[] ColorSteps;
ColorPalette = SetColorPalette(1, out ColorSteps);
for (int i = 0; i < ColorPalette.Length; i++)
ColorGridSeries1.AddPalette(ColorSteps[i], ColorPalette[i]);
catch (Exception ex)
MessageBox.Show(ex.Message);
private Color[] SetColorPalette(byte Index, out double[] ColorSteps)
double max;
double min;
ColorSteps = new double[100];
ColorSteps[0] = 0;
ColorPalette[0] = Color.White;
for (int i = 1; i < 100; i++)
ColorPalette[i] = CoolColorCode(i);
for (int i = 1; i < ColorPalette.Length; i++)
ColorSteps[i] = i;
return ColorPalette;
private void tChart1_GetLegendRect(object sender, Steema.TeeChart.GetLegendRectEventArgs e)
private Color CoolColorCode(double ColorValue)
ColorValue = 100 - ColorValue;
if (ColorValue < 0)
ColorValue = 0;
else if (ColorValue > 100)
ColorValue = 100;
if (ColorValue < 25)
return Color.FromArgb(255, Convert.ToInt16(ColorValue / 25 * 255), 0);
else if (ColorValue < 50)
return Color.FromArgb(Convert.ToInt16(255 - ((ColorValue - 25) / 25 * 255)), 255, 0);
else if (ColorValue < 75)
return Color.FromArgb(0, 255, Convert.ToInt16((ColorValue - 50) / 25 * 255));
return Color.FromArgb(0, Convert.ToInt16(255 - Math.Round((ColorValue - 75) / 25 * 255)), 255);
1) Perhaps I'm not explaining the problem well enough. The blue squared symbol with a value of 15.175 in the attached image "unknown.jpeg" - I would like to have that moved down to the very bottom and the red squared symbol with a value of 128.577 to stay at the top. In that way do make the legend values show a larger range of values and colors
Hi Friis,
1. This highly depends on the chart size. Another variable you can throw into the mix is Legend.VertSpacing:
You can make those values relative to the chart height.
this.tChart1.Legend.VertSpacing = 10;
Hi Narcis,
OK, vertspacing makes it look a little better...
But, for instance, in the attached image "unknown.jpeg" there are 10 symbols ranging from 0 to 128.577 - isn't it possible to increase this number to a larger number so that you accomplish a smoother gradient and larger gradient?
for instance, in the attached image "untitled.jpg" the legend is very smooth and there are an "unlimited" amounts of symbols ??
- untitled.jpg (21.86 KiB) Viewed 20091 times
Hi Friis,
You'd better use LegendPalette tool for that. You'll find an example at "All Features\Welcome !\Tools\Legend Palette" in the features demo available at TeeChart's program group. This applied to your example:
//this.tChart1.Axes.Left.Title.Font.Size = 14;
//this.tChart1.Axes.Bottom.Title.Font.Size = 14;
ColorGridSeries1.Add(x, x * z, z);
legendPalette1 = new LegendPalette(tChart1.Chart);
legendPalette1.Series = ColorGridSeries1;
tChart1.GetAxesChartRect += tChart1_GetAxesChartRect;
tChart1.Panel.MarginUnits = PanelMarginUnits.Pixels;
tChart1.Panel.MarginRight = legendPalette1.Width + 10;
private Steema.TeeChart.Tools.LegendPalette legendPalette1;
void tChart1_GetAxesChartRect(object sender, GetAxesChartRectEventArgs e)
legendPalette1.PositionUnits = PositionUnits.Pixels;
legendPalette1.Top = e.AxesChartRect.Top;
legendPalette1.Left = e.AxesChartRect.Right + 5;
legendPalette1.Height = e.AxesChartRect.Height;
ColorSteps[0] = 0;
ColorSteps[i] = i;
if (ColorValue < 0)
ColorValue = 0;
ColorValue = 100;
That looks MUCH better - Thank you
However, if I set the
this looks strange - the font at the legend palette looks bold ??
legendPalette1.Transparent = false;
- StrangeLookingLegendPalette.png (7.68 KiB) Viewed 20074 times
- LegendPaletteOK but not transparent.png (8.08 KiB) Viewed 20083 times
Hi Friis,
This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Hi Again,
How do I add a title to the legendPalette?
The following code does not work?
and
just adds a title to the chart itself ?
legendPalette1.title.text = "sasasf";
legendPalette1.chart.header.text = "dsf";
- Guru
Yes; in the meantime, a simple workaround is this:Narcís wrote:This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Steema.TeeChart.Tools.LegendPalette legendPalette1 = new LegendPalette(tChart1.Chart);
legendPalette1.Series = tChart1[0];
legendPalette1.Axes.Chart.Graphics3D.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SystemDefault;
legendPalette1.Transparent = true;
- Guru
Try:Friis wrote:just adds a title to the chart itself ?
legendPalette1.Axes.Chart.Header.Visible = true;
legendPalette1.Axes.Chart.Header.Text = "asasas";
Just implemented both of the solutions you have presented here - it works fantastic both of them - thank you
